Question about Intel Motherboard
MSI 1996 Motherboard: Power on Signal to PS staying high
P-ON should enable 3.3 &12v to Motherboard when start button is pushed. The signal stays high and if i disconnect it and put the ps side down to 0v everything is fine PC works beutifully. Only drawback ps and fan remain running following normal PC shutdown. I have noticed the abscence of any audio from PC. Medion the PC manufacturer say it will be static and advice i get a new Motherboard. What do you think?? I have asked this question on another forum with no response.
  • marshall123 Jan 11, 2009
    170+ hits and not one sensible answer?? Where are all these wiz kids???
    Problem Solver:
  • 10 Answers
Hi
reset and see
Posted on Jan 02, 2009
Check motherboard wire conector, make sure its not reversed
Posted on Dec 24, 2008
How do I get the headlight to stay on high bean
try pushing the turn signal stick forward. if that does not work, you may need a new switch.
Nov 23, 2014 | 1988 Lincoln Town Car
High beam wont stay
do you push or pull the turn signal combo switch for the high beams? If you pull it towards you, try pushing it away from you. If neither stays on, the switch needs to be replaced!
May 25, 2013 | 1994 Toyota 4Runner
When booting, I get a black screen
Motherboard faulty. need repairs
Dec 07, 2012 | MSI K9AGM2-L Motherboard
On button will not stay on
hi,
This is not the button issue but motherboard issue unless button is not stuck . So you will have to replace motherboard .
(The motherboard is not able to hold the signal that we apply through power button. If power button has issue , you will not be able to power on server at all)
Thanks
Dec 03, 2011 | IBM x3400 Server
I have a viper remote start that came with the used i car i bought, the remote start worked great for the first few months of winter, now when i start it up, it runs for 2 seconds then dies, takes up to 6...
Your alarm may have lost the tach signal, that was learned to it, when it was originally installed. That would cause the remote start to try starting the vehicle over and over again, until it finally stays running, because it can't read the engine speed to know it's running.
If you can find the valet push button switch in your vehicle, try this; Start your car with the key and immediately after it starts, press and hold that valet push button switch until the alarm led on the dash stays lit up or the park lights flash. Then, release the valet switch, shut the car off and try remote starting it. That is the procedure to re-learn the tach signal. Hope it works for you.
Feb 10, 2011 | Remote Start System
Installed the board, scren displays message no signal and stays black. no peeps or beeps. usb has power so do drives and signal leds
Check the cable between your monitor and computer. If this is a new install and you have added a graphics card, you will need to boot up once using the on-board VGA. Doing so will allow you to turn off the on-board VGA in the BIOS. Then you can shut down and move the monitor cable to the new graphics card and reboot.
Dec 05, 2009 | MSI G31M3-L V2 Motherboard
Pc won't start
try to reset BIOS by CMOS battery from motherboard and insert again...if not worked then..ur motherboard needs to be replaced...
Feb 04, 2009 | HP Compaq dc5100 PC Desktop
I have a 5 year old Dell Dimension 8300. Lately I have been having problems getting it to come on and stay on. Once running, it stays running great. Today it wont stay on. I hit the power and sometimes it...
It is likely your power supply is failing. When you press your power button a signal goes through the motherboard to the power supply, then the PS comes on. I would try a replacement power supply first, you can get a used one for less than $20.
Dec 31, 2008 | Computers & Internet
Computer won't wake up
ok, there could have been a graphics issue in the bios caused by the windows graphics drivers, heres what you could try........... remove the power cord from the back of the machine, remove the side panel to allow access to the motherboard, you will see a battery! take it out for 10 mins and push the on/off button a couple of times, this will drain any remaing power from the motherboard, after 10 mins the CMOS should have cleared so you can replace the battery, plug in the power and turn the machine on hopefully you'll get a signal
good luck
Nov 17, 2008 | Computers & Internet
Intel Motherboard Logo
1,286 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
