Question about Acer AL1912 19" LCD Monitor
Acer AL1912 Monitor Looping
I turn on the monitor and the acer logo comes up and a moment later the bottom green power light goes off and the monitor resets itself and starts up to the logo again and i can not turn it off by hitting the power button i have to unplug it to get it to turn off. If i plug it into a machine it will display what it should and then resets again and again.
  • 4 more comments
  • Anonymous Jan 05, 2008
    I am having the same problem with mine.
  • sovermyer Jan 19, 2008
    Acer AL1916 - same problem. It usually occurs in 'bursts', cycling on and off every few seconds, several to a dozen times, then it will be O.K. for days. I have been unable to associate it with temperature, time-on, display content, etc.
  • LilJep Feb 27, 2008
    Mine is an AL1912 but there are no 3 screws on the button area, only 4 on the back and I can't seem to get the cover off. I'm having the same issues. Help?
  • Anonymous Sep 04, 2008
    I have exactly the same issue as the rest here. Problem is I have not figured out how to get the monitor open to I can clean the corroded area.
  • Anonymous Nov 27, 2008
    Same problem, but I specifically associate it with turning the monitor on cold. For example, if I leave the monitor on all night with a signal source going (ie. leaving the computer on also), then there is no problem since the monitor was never turned off. When the monitor is left off, usually overnight, then turning it on in the morning will cause it to loop a few times, but it usually regains stability by the time the boot up process of the computer finishes, so it is more of an annoyance than real problem.
    Whatever the internal degeneration is, it seems to be affected by temperature. The cooler the monitor starts out, the longer the looping event will be. Of course leaving the monitor and computer on will "solve" the problem, but waste a lot of energy too unnecessarily. Given that it is temperature related, I suspect it might be from condesation on some critical contact, but as the monitor circuitry heats up, the condensation burns off allowing normal operation.
    The local temperature charts where I live are typified by a sudden cold snap when winter approaches, and subsequent "winter" temperatures for several months, so the problem was much more delineated for me. Prior to the cold snap, the monitor worked normally, after the cold snap the morning power-ups began looping.
  • JOJO2JOJO Jan 23, 2009
    Same issue, stays on for 30 seconds when bootiong up, then starts intermittently off and on. Jsut a pain, I wish Acer did not make that kind of equipment, as it is expensive.
    Anyone figured out what is causing this, must be a circuit board failure or connection failure.
Hey Vine or Jinksko: I'm having the same problem. I got the cover off and the circuit board snapped out, but I don't see how to remove the ribbon cable from the board without breaking it. It's a white plastic connector - what do you do to disconnect it? Thanks!
Posted on Oct 31, 2009
I also had this problem, after googling for Aceral1912 troubleshooting, found this site and followed the advice above about removing the button circuit board, low and behold I found a spider had taken residence inside the monitor, and the remains of the flies he had been feasting on were shorting out the circuit board!
Thanks fixya! saved me £££££££
Posted on Oct 27, 2009
I'm having the same isues and there are no3 screws on the button area. model AL1912. Help?
Posted on Feb 27, 2008
I have fixed many of the al1912 easy fix
the problem is always corrosion on the circuit board that has the buttons
disassemble the flat panel remove 3 screws that hold button board on
disconnect the tiny cable from the button board
use a tooth pick and clean inbetween the solder connections where the ribbin cable plugs into button board
Posted on Feb 18, 2008
I use Acer AL1912 19inch (black) monitor. It is working properly for weeks. but sometime it suddenly go dark during work, although its light remains green. Now the only solution is to unplug its power...
Sounds like the monitor is dying, if it starts to die more and more often you will likely have to replace your monitor before it goes completely out. There are not many ways for a user to repair a monitor, unless the problem is with the computer, which you could test by connecting a different monitor to the computer for a while (if available). Hope this helps!
Mar 15, 2011 | Acer AL1912 19" LCD Monitor
I have a AL1912 B monitor that won't turn on. The green light in front just keeps blinking.
Power board problem, in all probability capacitor failure. Needs the capacitors checking and replacing, but will probably be cheaper to get another monitor
Jan 12, 2011 | Acer Computers & Internet
My monitor takes forever to load. It only started to happen recently no more then a week or 2. Every time I turn on the monitor the green light blinks several times. After it stops the monitor just keeps...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | Acer AL1912 19" LCD Monitor
My monitor takes forever to load. It only started to happen recently, no more then a week or 2. Every time I turn on the monitor, the green light blinks several times. After it stops, the monitor just...
Most likely caused by defective capacitors in the power supply. This is quite a common problem.
If you have some electronics skills, you may be able to change them yourself - look for bloated, otherwise deformed or leaking capacitors, typically in the 470u - 1000u / 25V range. Replace them with 105°C rated low ESR types of the same value and voltage rating.
If you don't know what I am talking about, bring it in for repair (if it's still worth it...).
Mar 19, 2010 | Acer AL1912 19" LCD Monitor
Acer AL1912 19" LCD Monitor goes black after power up
With the screen connected to the pc (which is running and putting out a signal) hold a bright light to the front of the lcd - a led flashlight works well. Do you see an image? If so then circuitry driving the inverter backlights may be at fault. I had this happen with a Dell Flat Screen, and found one of a pair of transistors which drives the backlight had developed a short.
Aug 01, 2009 | Acer AL1912 19" LCD Monitor
My acer AL1912 monitor keeps going fuzzy. It kind
An unusual problem for a flat screen monitor.
I suggest you connect the monitor to another PC to see if the problem persists since it could also be caused by the video card (or circuit, if on board).
Check your cables making sure they are solidly connected and wiggle them to see if you can cause the problem to come or go away; this would crudely check the shielding of them.
This kind of aberration could easily happen with a conventional CRT monitor if power supply filtering was failing but as mentioned, uncommon in a monitor that is essentially digital.
May 12, 2009 | Acer AL1912 19" LCD Monitor
No Signal
Not all monitors can display the same resolutions. You may have has the Dell monitor set at something the Acer can not handle. Try rebooting and if you can see the Dell startup screen press F8 as soon as it disappears. This will give you the Windows Startup Options menu, which is text and should display on any monitor. Then select VGA MODE, which is the lowest common denominator for graphics. You should be able to see the Windows display at a much lower resolution (ie, larger fonts and icons) than usual until you can reset your graphics properties to work with the new monitor.
Dec 28, 2008 | Acer AL1912 19" LCD Monitor
Acer AL1912 Monitor - Screen to black and light on yellow
I found some solutions other posted that didn't come up the first time I looked. I did a reboot and I'm good to go!
Dec 07, 2008 | Acer Computers & Internet
No display
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
Jul 30, 2008 | Acer AL1912 19" LCD Monitor
Acer AL1716 Power problem?
i have experienced the same problem (power cycles on and off and on and off... nothing but Acer logo and black screen) on 2 Acer model 1706 A version 1706 Ab monitors both built in July 2006. Before the customer reported the 2nd monitor with the same problem, i sent the 1st one into Acer for warranty service (after testing in on 4 machines w/4 different video cards). They shipped it back with a paper saying the monitor was repaired. I returned the monitor to the customer and it exhibited the same symptoms (aka, not repaired). Could there have been a bad batch in July 2006? When I plug a new Acer AL1716 monitor into the same computers, I have no problems at all.
Jan 18, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1912 19" LCD Monitor Logo
514 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
