Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Dirty glass on oven door
How can one safely clean the baked on stains on the glass on the oven door. I know we shouldn't use harsh abrasives but those brown stains seem to have become part of the glass. Are we just stuck with it.? I'm afraid that some day we won't be able to see through it.
  • jhwms Dec 23, 2008
    During the one time I used the self-cleaning, the glass did not come clean, but I don't recall how long or what temperature was used. But, I will try again. Thanks.
    President:
  • 1,901 Answers
Does your stove have an electric self-cleaning cycle?
If so, do it. I was surprised how well it worked on the glass too!
Remember though it may take 3-4 hours at a very high temperature.
Posted on Dec 23, 2008
How can oven door glass be cleaned?
The window is comprised of two pieces of tempered glass with a metal band seal around the outside. Because the metal and the glass have different rates of heat expansion, material expelled by baking items finds its way past the seal and in between the two pieces of glass. As a practical matter, it is better to live with the dirty window than to risk destroying the oven door to remove and clean it. Besides, if you were able to remove the window assembly how would you remove the metal seal, separate and clean both pieces of glass, and reassemble?
Apr 05, 2016 | Ovens
How can I clean the oven glass and oven
Suggest using a razor blade paint scraper...the kind that you use to scrape paint off of glass after painting the wood. A paint store or paint department in Lowes can supply this. It is a small handle that holds a razor blade.
Jan 06, 2018 | Ovens
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
Acid rain on car windows
Follow the below steps ;-
  1. Clean your window as normal, with a lint-free cloth. Spots left over from acid rain are sometimes difficult to discern from simple water spots--with luck, your glass is only dirty, and not damaged. Follow up the initial wipe-down with an application of Windex. Try to let the window dry out of direct sunlight, in order to prevent ugly streaking.
  2. Dust the spots with a thin layer of baking soda (sodium bicarbonate). Take a damp rag, and scrub the water spots with a liberal amount of elbow grease. The baking soda is an effective, readily-available abrasive medium that will remove the spots without damaging the underlying glass. For an extra abrasive edge, consider scrubbing with an old toothbrush. If the spots persist, however, move on to Step 3.
  3. Apply a small amount of cutting compound to a super-fine (Grade #0000) steel wool soap pad. Cutting compound suspends an abrasive in a paste that can then be applied to your glass, and the soap pad will scrub more effectively than a simple cloth. Do a test on a small patch of glass before you apply this method to the whole window, to ensure that your window will endure treatment.
  4. Attack any remaining spots with the same amount of vigor and elbow grease--acid marks can be incredibly persistent, and at this point you're polishing more than you are cleaning. After an appropriate amount of effort, check to see if any stains still persist. If stains are still readily detectable, try repeating this step while using a cutting compound of smaller grit size.
  5. Assess the final result, after all reasonable effort has been exhausted. As the name suggests, acid rain actually etches into the surface of the glass. If the damage is extensive enough that it impairs the functionality of the window, you may have to bite the bullet and obtain new glass.
You can also refer this Video :-
http://www.ehow.com/video_4908483_remove-acid-rain-from-car.html
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 14, 2009 | Toyota Highlander Cars & Trucks
If I DO NOT want to use the self cleaning feature is there any other safe way, including using soap and water, to clean the oven without ruining it? (I don't want to use the self cleaning feature)
  1. Oven door : Wash the door and window with soap and water and rinse with clear water. Use glass cleaner only if sprayed on a cloth first. Do not use abrasive pads, powdered cleaners, or steel wool on glass and enamel, or the surfaces will be scratched.
  2. surface burner : To absorb a spill when it is hot, pour salt on it and wipe it up when the oven has cooled. A mildly abrasive baking soda and water paste can be used in the oven, too.
  3. Racks:Remove oven racks and clean them in warm, soapy water. Stubborn messes can be cleaned by using mild abrasive cleansers or a soap filled scouring pad. Rinse and dry the racks before returning them to the oven.
  4. Metal trim:Metal trim can be cleaned with glass cleaners or mild cleansers, soap and water. Abrasives or cleaners made for oven interiors should not be used.
Thanks
Smith.
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Clean glass range door
Hello. I recommend a product called Cameo. Cameo is a non abrasive cleanser actually designed for the new type enameled sinks recomended by American Standard. AND iit works great on oven door glass. You can get it at Walmart. Very inexpensive and works great on all kinds of surfaces that may be hard to clean but you don't want a harsh cleaner that might damage the surface or scratch. Has a very light to almost none scent. Very good for cleaning the oven both inside and out. Doesn't have the chemical smell left by some cleaners that can be intensified by heat.
Aug 14, 2009 | Frigidaire 27 in. Electric Gallery Pro...
How to remove smoke stain ?
Try a mild abrasive cleanser like Bon Ami or Soft Scrub and wipe clean.
Nov 10, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning
get some ceramic glass cook top claener.that will take care of it
Mar 28, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
405 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
