Question about Sprint Hitachi P300 Cellular Phone
My Hitachi 50" TV's color has turned very green
I have manually altered the color to make it more 'normal' but it's not. I can't even watch a black and white - it's now more green and black and very, very dark. A friend of mine mentioned that it most likely was a bulb out - how many bulbs does it have? If this is the problem - could I fix it?
Thanks much for your time and assistance!
  • prockcastle Dec 29, 2008
    The response I got did not help - but thanks. Further not only is the picture green, but very very dark. Brightness is on 100% along with Contrast at 100%. I've tried manually adjusting all colors but it's primary color is still green... a new bulb perhaps? Can I do this myself?
  • 128 Answers
My intelligent guess of what happened is you might have problem in your Y-signal around your video amp section somewhere. Somehow within each frame of the video signal, the voltage representing green color overwriting the actual video signal. After your TV got warm up, the white signal was gone, so you can't see the actual video.
In Y-signal, high voltage in a video frame gives white color, black is low voltage. Everything else is in between. Do I make any sense?
I think the repairman can figure it out for you, but you have to negotiate for reasonable price. If he has a scope, he can find this type of problem quickly. Around my area, just for a repair man to look at the problemed TV cost $45, fixing and parts are extra.
Posted on Dec 29, 2008
  • 4,234 Answers
First of all, without the model number any response here is pure speculation. There are a number of reasons for a darker picture. If you would be so kind as to provide the model number, I will be able to give you more details and instructions on how to best resolve this problem.
Thanks,
Dan
Posted on Dec 23, 2008
  • ABRsvcs Dec 29, 2008
    In direct response to your question, yes in all likelyhood, you can fix this yourself. Please post the model number so I can give you details and instructions.
    Thanks,
    Dan
    President:
  • 2,110 Answers
Try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
  • 15,935 Answers
3 bulbs - yellow, blue, red. if it is rear projection.
Simply open the back panel for the projector, and see if the bulbs are lit.
  • blueextc3221
    blueextc3221 Dec 23, 2008
    sorry, red green, blue
    Lamp Replacement: This is the biggest detraction to rear projection televisions because lamp replacement can be expensive. A typical replacement lamp for DLP, LCD and LCoS costs at least $200. Most rear projection owners will have to replace a lamp every 3-5 years. Owners of CRT rear projection have an added disadvantage in that when one of the three guns (red, green, blue lamps) goes bad, it is recommended to replace all three to keep the colors balanced. Replacement of those lamps is even more expensive because a professional technician is likely needed to install and calibrate the lamps.
  • blueextc3221
    How do I know when it is time to replace my lamp?
    Trust me, you’ll know. The screen will lose its brightness and appear dim. You won’t necessarily have to replace the lamp when you notice the dimming. Some people might wait until the bitter end to install a new lamp while others will have one in reserve waiting for the screen to dim. It’s a matter of choice.
    How much do replacement lamps cost?
    Unfortunately, replacement lamps for all projection televisions are costly – in the over $200 range. Depending on the type of lamp and manufacturer, the cost will vary considerably. Where can I buy a replacement lamp?
    I suggest contacting your manufacturer to see what lamp they recommend for your particular television, and to see who is an authorized dealer in your area (if any). There are a lot of good online stores that can send you a lamp usually for a lower price, but I would be a little wary about ordering something fragile like a replacement lamp through the mail. My concerns are that the lamp would be damaged in shipping, and the online retailer might be difficult (a rare case) to work with regarding replacement of the replacement lamp.
    Are they easy to install?
    My answer is yes, but I must qualify that by stating it all depends on who is doing the installing. Some models of televisions might be more difficult than others. Usually, it should be as much or little as twisting a screwdriver, pulling the lamp out, inserting the new one, and turning the set back on. This is definitely something to ask about before buying your television.
Model 51S715: 2 issues: (1) Screen is bowed at top...left and right edges turn down and are black. (2) picture color will turn green randomly. If I turn tv off and leave off for a while the color goes...
Ur tv have a problem call convergence,it dying about to be dead.The tv convergence board 2 STK Convergence ICS and some or all it resistors require changing to solved the covergence problems.U have tools,soldering iron,solders and know how to do soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
Sometimes after the my TV is one for 20 mins or so the screen warps, shooting white/pink/green lights across the top and bottom of the screen and placing a horizontal black line at the bottom like hal
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 19, 2009 | Hitachi 50FX20B 50" Rear Projection...
Image green tinted.
TRY VIDEO CONVERSION OPTION IN THE MENU,,IF NOT TRY NEW CONNECTERS
May 15, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50v500 goes black and then comes back on.
Sounds like the light engine. They are having major problems with it, but Hitachi is replacing the part for free, with you paying for the installation. Need to call Hitachi customer relations.
Dec 05, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
The color is all off, no red, the green is too much it does not look right
Which inputs are you using? If your using the composite inputs the cables may be switched.
Aug 18, 2007 | Polaroid FLM-4234BH 42 in. LCD HDTV
No power on Hitachi 50UX588
Most likely have a regulator problem. Remove rear cover, look down on the main chassis, turn tv on watch the board to have some colored led's lit, usually a red one and couple of green. If the red is out, its your regulator, if a green one other problems off the circuit with green led are causing the tv not to power up.
Jul 22, 2007 | Hitachi 50GX49B 50" Rear Projection...
Hitachi 52 projection tv
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Sprint Hitachi P300 Cellular Phone Logo
Top Sprint Cell Phones Experts
Vernon Taylor
rgnestle
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
