The front left burner does not light. The ignitor appears to be working (sparks when burner knob is turned on). I could not get the burner to light with a match so I suspect there is not gas getting to the burner. The other burners work well.
SOURCE: My Thermador Range (Model #GCV36G)
A yellow flame that high indicates that the air input is low so the mixture is too rich, so it lights very hard and it gets a poor flame.
The defect is in the burner, it's clogged by dirt. Try to clean it from the outside just by pulling every loose parts. If that fails the top of the range will have to be removed to access the entire burner, take it out from it, dismantled and cleaned thoroughly.
You can find the necessary diagrams here
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232125&diagram_id=193462#d193462
But i must warn you: you will be working on a gas unit; if you can't be sure you can do the job properly, without causing any leaks afterwards, you should call a repairman.
I am having trouble accessing the electronic components under the stovetop and don't want to force it too much. I have not been able to find a manual that describes how to get to the components. Anyone know how to di it?
I know this question is 6 years old but I have the exact same problem! Was there a fix?
