Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Where do you hook up coaxial cable? Rear port looks like it needs
I just purchased a Magnavox ZV4279MG9 Digital Video Disc Recorder.
I do not see a port for the co-axial cable that needs to attach. The back port looks like it needs some type of adapter?
How do you connect?
  • Elise Morris Jan 12, 2009
    I need to know what a coaxial cable is- it seems there needs a converter to change the wall coaxial cable with signal to an rca-type of male ended plug. Can anyone tell me if such a converter exists, where to get it, or if there is any other solution to this problem?
  • dacarroll Feb 19, 2009
    I have no cable or satelite box. I have one cable coming in from our cable company. This does not connect any where to th DVD recorder.
SOURCE: hooking up a magnavox MWD7006 DVD player to a APEX TV
Here's the manual:
http://www.funai-corp.com/6pdf/om/MWD7006.pdf
Posted on Jul 05, 2008
SOURCE: DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Posted on Sep 14, 2008
SOURCE: Viewing a recorded DVD+R on PC
when try to record cassette to dvd e 25 pops up
Posted on Sep 25, 2008
  • 57 Answers
SOURCE: DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Posted on Jul 06, 2009
  • 44 Answers
SOURCE: Coaxial cord won't fit on VCR/DVD
TV-Video | DVD-TV
Posted on Jul 08, 2009
In what port do I use to install an ONN digital optical audio cable? I have a Seiki Model SE322FS
Based on the specs from CNET, the Seiki SE322FS does not have an optical digital audio port. There is a coaxial digital audio port which looks like a standard RCA jack. The main difference is that it will be a single output jack, instead of the groups of RCA input jacks (component and composite audio/video ports). See https://www.cnet.com/products/seiki-se322fs/specs/ . See https://www.lifewire.com/coaxial-vs-optical-digital-cable-3134605 for some of the pros and cons for each type of digital audio cable.
Since the TV will be your audio source, you'll need a coaxial to optical digital audio converter. This is one example: https://www.cablestogo.com/product/40018/coaxial-to-toslink-optical-digital-audio-converter-taa-compliant . Note: usually the cables are not included with the converter. Thus, you'll need to get a coaxial digital audio cable separately. A different converter is needed to go from an optical digital audio output to a coaxial digital audio input.
I hope this helps.
Jul 25, 2018 | Seiki Televison & Video
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
Why does neither the co-axial cable from my DVR Cable box nor the one from my TV fit into the coaxial plug on the Magnavox ZV427MG9 DVD Recorder/VCR Combo ?
Check the coaxial cable connector type. There are two kinds--one that look like the RCA connector that you can just push in.
The other kind has a nut that you have tighten over the coaxial cable connector on the DVD recorder.
Dec 05, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Connect magnavox dvd to ge tv HELP!
You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
Cheers ... Best wishes
Jan 30, 2009 | Televison & Video
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
TiVo installation
Since the Series2 doesn't do HD, you don't need any fancy connections, and it's pretty simple to hook up.
1) Disconnect the cable that's connecting your cable box to your TV, from the TV end.
2) Connect the end that *was* connected to your TV, to the "input" on the Tivo.
3) Get another piece of the same cable (coaxial cable), and connect the output of the Tivo to the input on your TV.
That's it.
You may just need to go to Best Buy and get a piece of coaxial cable to connect the Tivo to the TV.
If you need further help, let me know.
Dec 15, 2008 | Tivo Series2 Digital Video Recorder...
Hook up
connect yellow white and red cables FROM AUDIO/VIDEO out from the dvd player to the tv. connect your cable wire or coaxial cable to this unit. (the first one is going to be on your tv disconnect that one and put it on this unit where it says ANT IN.) connect the cable that came with it on ANT OUT or a cable that you might have and then turn on tv. and use your original remote to your television and look for a button that is regarding input or tv/video or tv/av. This function will only be on your tv remote. NOT DIRECT TV.
Dec 29, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Video input not recognized for LD and DVD
By coaxial, do you mean the composite (yellow)? Either way you have to use the same style no matter what the cable. I mean, if you have s-video's IN to the reciever then you need S-videos OUT to the TV. ....Component IN to the reciever? then Component OUT to the TV. And so on. You cant have composite cords going into the reciever and use a component cord out to the TV (with the exception of a few models).
Sep 10, 2007 | Pioneer VSX-D912 Receiver
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
