Question about Saeco Magic Comfort Plus Espresso Machine
Please help the coffee is not hot enough and i changed the t stat and its a lil better but im not satisfied with the temp im getting is there a diagnostic mode i could go into to change temperature
  • 1 more comment
  • iberital Feb 05, 2009
    I have the same problem. I have changed the boiler,thermos and checked wiring. Unit runs @ 80 degrees.
    Please help
    Sanremo
  • dave pi Feb 13, 2009
    Our coffee also used to be hot and delicious, and now is neither. Temp is too cool, even at hottest settings. Coffee flavor is thin even at most robust setting and brand of coffee has not changed. Any suggestions?
  • bsmarkone Mar 16, 2009
    I just bought another Saeco magic comfort, and it is not hot enough. I have one at work and it works fine almost to hot.
    Problem Solver:
  • 14 Answers
The Magic Comfort Plus machine has a selection for the temp through the menu for the three sizes of coffees buttons. Using the menu button, scroll through until you come to temp section, then select the coffee size button and and change the temp, example-- Select maximum. Press the menu button to set it.
If that does not help, when a machine gets full of calcium (needs descaling) that also will lower the temp. You might have to descale it three-four times.
And remember, when you descale, run the solution through the steam/hot water wand and also the espresso/coffee dispensing nozzle. Only doing it through the steam wand (like the manual says) will only do 1/2 of the machines water sections!!! I usually run 1 cup of solution through the steam wand and 3-4 cups through the espresso dispenser.
Posted on Apr 22, 2009
What can i do to get better heat in cabin area of this car
You need to get a hotter stat for winter....plus you need to reduce air flow into radiator. You can reduce flow by installing a piece of cardboard in front of radiator. Please only cover partially as complete coverage coyld cause overheating. You are only teying to reduce not elim
A thumbs up would be greatly appreciated if this answer is helpful to you.
Dec 19, 2014 | 2000 Chevrolet Monte Carlo
Coffee not hot enough
Ive had this machine for over 3 yrs now and agree the coffee could certainly be hotter. I usually blast hot stream from the milk jug by pressing the clean button for 5-10 secs. This does help. Also by having the cups heated up on top of the machine also helps. But i usually always give the completed coffee a 10 second blast in the microwave to get it to the temp i like. Its not ideal i know, but there seems no other way. Oh and make sure the temp is on high in the menu.
Dec 11, 2012 | DeLonghi ESAM6600 Espresso Machine
I own the Ikon BES400XL and the coffee does not seem hot enough. Temperature on turning it on is 140 and gets to 160 if I let it warm up. Shouldn't it be around 200F? What gives? Is it something I can...
It was set to that temp by the factory, check the thermostats on the boiler of the machine, those are the set temps. If your machine has a pressure stat you might be able to adjust it to a little higher, never go past 198.
Aug 10, 2010 | Breville BES400 Espresso Machine
Temperature fluctuates
Actually that thermostat is adjustable for only +/- 1 degree. I would make sure it is located close to a radiator/register, whichever you have, to help close that 8 degree variance. The thing about hot water heat is that even when the boiler shuts down those radiators are still putting off heat, so the temp can still shoot up a few more degrees after the stat has been satisfied. Is the boiler shutting down when the stat hits 71* ? If not then the stat may be bad. Honeywell carries a 5 year replacement warranty on that stat. I use the Honeywell Focus stats in almost all my installations. They are a very dependable thermostat. Feel free to ask anything else that will help solve your problem...Rob
Dec 16, 2009 | Honeywell Focus 6300B 5-2 Days...
4.3 liter won't gain temp, why?
The chevy blazers are known fior heater core issues clogged going bad etc... The reason im saying this is because the only reason i could see you having a problem with the temp not getting hot enough is because then your heat in your car isnt getting hot or its taking super long to get luke warm, is that correct? If so 9 times out of 10 its a bad heater core...
Thanks,
Steve
Jan 19, 2009 | 2003 Chevrolet Blazer
WEAK COFFEE & NOT HOT ENOUGH
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Dec 22, 2008 | Bunn NHB Coffee Maker
Coffee not hot enough!
You could replace the part but you might want to try a better brand like Krups or Braun
If you have a sentimental need to keep it you could have the thermostat and hot plate replaced
eric
Nov 14, 2008 | GE 106591 Coffee Maker
Won't perk properly
Oct 21, 2008 | West Bend 13500 Coffee Maker
The water that comes out thru the coffee gounds and into the carafe is only warm not hot.The coffee that is brewed is weak and only warm.
Sep 12, 2008 | Krups Small Appliances Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
176 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
