Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Snowblower cuts out,
Had new motor installed last do i ajust thordle.i have no manual.modle-38182,sn.-220022243,can u help me .
  • 76 Answers
You have a single stage Tecumseh engine in that, if you look at the nut that holds the bowl on it should have the main bolt that holds the bowl and what looks like a screw going thru the center of the nut, the screw part is your high speed idle adjustment. While machine is running turn the screw in just a little at a time listening for the idle to go up. If it doesn't go up and it starts to bog then turn the screw out and listen for the same thing .when you here the idle go up then it starts to go back down then turn it back to peak and your set. It's best that you do this when it's cold so you can run it long enough to adjust, other wise it's not good to run it for any length of time in warm conditions.
Posted on Jan 07, 2009
Mastercraft Snowblower 8hp28inch cut.Snowblower starts to miss and run rough after it is warmed up what is the problem
This link should help:
Feb 05, 2016 | Garden
My snowblower starts then stalls
Rob; 95% sure it is a carburetor issue, dirt clogging a port or jet,float sticking. I will post a few sights below to show how to clean carb.
How to Fix Snow Blower Carburetor
HOW TO Clean Rebuild Tecumseh Snowblower Carburetor PART 2 OF 4
how to rebuild snowblower carburetor
Jan 30, 2016 | Cars & Trucks
Install scarper blade toro powerlite mod. 38182
On everyone I have ever seen, there are just three bolts that go through it into the auger housing. There is a notch that the scraper has that fits on to the end of the housing. You can see the drawing for it here -
I just picked one of the models for 38182 cause i think they are likely all the same, but if you want to be sure, use the list here - and choose the one that matches your serial number range. Then select the drawing to see the rotor assembly. Should be pretty easy except sometimes the heads of the bolts to keep the scraper on get wore down if the scraper bar wasn't changed when it should have been.
Jan 09, 2015 | Toro Power Clear 210R Part 38587
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Honda snowblower problem
yes you can adjust the throttle cable, did you leave gas in it over the season, if you did this is definitley the problem, dump out the gas and pour new.
Feb 25, 2009 | Garden
Honda snowblower engine hunting
Sounds like you are hitting the governor. Watch the arms at the carb when you move it to full throttle. The arm should hit a screw. Turn this screw clockwise, until the reving stops.
Dec 08, 2008 | Garden
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
218 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
