Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jennair electric range 2B ceran module - one burner not working
Purchased in 2/04, the smaller (rear) burner on the modular radiant cooktop module stopped working. the front burner works fine. the control knob light indicates power source is functional, and plug is clean.
    President:
  • 2,692 Answers
When oven circulating fan is on there is a virbration. how do you locati the fan?
Fan is located in rear of stove or maybe a piece if foil paper for into blades
Jan 05, 2015 | Whirlpool Gold GY399LXUB 30" Slide-in...
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
Mar 11, 2012 | Cooktops
My spark module is probably out, but I don't know how to open up the range to look at it/replace it. How is this done?
Most newer ranges with sealed burner cooktops can be a little bit tricky to open. People have a tendency to try and lift the cooktop up like on the older ranges and end up damaging the range and causing a gas leak. The first thing to do is to unplug the range of course. Then start by removing the rear panel of the range. From there you can get a visual feel of what you are up against. With the back panel removed you should be able to see into the top part of the range. Most newer sealed burner cooktops require you to disconnect the screws holding the burner tubes to the bottom of the cooktop. If you do not remove these screws you will break the tubes when you lift the cooktop. Most of the time the screws are removable from the top at the burner heads. Once these screws are removed you should be able to lift the cooktop up. From there the ignition wiring and spark module should be available now for servicing.
Apr 24, 2010 | Amana ARGS7650 Electric Kitchen Range
Kenmore electric cooktop not working on low eat
If it was the burner element it either would work or not (no in between)
It has to be the switch
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 13, 2010 | Kenmore Elite 44173 30 in. Electric...
Tappan ceran electric cooktop not working
check the wirings first that connect on the outlet of electric then the wirings that connect on yourtappan ceran electric cooktop...
Nov 26, 2009 | Tappan Kitchen Ranges
Jennair model # JDS9865BDP Dual-Fuel Modular slide-in Range Pro Style Burners are too hot to do regular moderate cooking. Wife says the left side burners (where grill goes)can't be adjusted low enough to...
pull off your selector knob and shine a flashlight down the shaft, depending on your model, you may have the adjustable mmodel
at the bottom of the selector shaft, you may see a flat head screw adijudt it at ver small increments
i believ a 1/4 turn in should turn your flame down quite a bit
hope thsi helps
Nov 02, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Downdraft Slide-In Range
I have the radiant cooktop (i.e., glass top) version of this range. I've had this same problem since I first purchased this unit. I wondered why no one answered this question, as I check back to see from time to time. I finally contacted Jenn-Air's online support. My conversation was as follows (I'm not entirely sure that the tech support knew what she was talking about, but here you go anyway):
message.gif?p_db_name=whirlpool Cidalia C: Hi, my name is Cidalia C. How may I help you?
message.gif?p_db_name=whirlpool You: Hello!
message.gif?p_db_name=whirlpool You: I have a question regarding my "Downdraft Radiant Cooktop"
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air today with your inquiry. What is your question please?
message.gif?p_db_name=whirlpool You: None of my burners can simmer-- no matter what the setting, they will boil water!
message.gif?p_db_name=whirlpool You: Is there an adjustment that can be made to attenuate the heat?
message.gif?p_db_name=whirlpool Cidalia C: What is the model number of your cook top please
message.gif?p_db_name=whirlpool You: JED8430ADB
message.gif?p_db_name=whirlpool Cidalia C: Thank you. In looking at your burner configuration, the smallest wattage on your unit is 1200. And, unfortunately, there is no way to get a small wattage for your burners. We apologize for the inconvenience.
message.gif?p_db_name=whirlpool You: Yes, but the dials are supposed to prevent the full 1200 watts from reaching the burner unless it's on maximum heat, correct?
message.gif?p_db_name=whirlpool Cidalia C: Yes, but the burners do not get low enough to be considered simmer burners.
message.gif?p_db_name=whirlpool Cidalia C: Did you have any other questions or concerns today?
message.gif?p_db_name=whirlpool You: I suppose not.
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air. Have a good day!
Jul 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Schott Ceran cooktop on Maytag range
try clr from a local supermarket.it comes in a green plastic bottle.wipe the burner generously but not soaking wet with it and turn the burner on the lowest setting.then use a metal scouring pad and LIGHTLY scour the burner.
Aug 11, 2007 | Maytag MER5775Q Electric Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
351 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
