Question about Microsoft Office Outlook 2003 for PC
Outlook.pst SEEMS to be hidden
When I do a Search (with the search-also-hidden ON) I can find my outlook.pst. However, when I use Windows Explorer to look in the sub-directory, I can not see it. I have already set Show-hidden-files ON.
I want to make sure it is backed up when my scheduled back up software is executed.
Thanks!
  • Tribble2 Jan 08, 2009
    I have the same problem.
    It is on my company Computer, Outlook 2003.
    I have a work around: export your PST contents to a PST file. Now, use that new file instead of the old for handling your mail, etc. This file will be visible in the directory.
I have found out there are two paths on my computer
C:\Documents and Settings\USER\Application Data\Microsoft\Outlook
C:\Documents and Settings\USER\Local Settings\Application Data\Microsoft\Outlook
Note one has Local Settings in it. This folder contains the default directory for the outlook files. Mine were split between the two directories.
Posted on Jan 12, 2009
  • Microsoft Master
  • 4,806 Answers
Hi there
When you find the file all you have to do is copy the file to your documents, if you have to right click on it, go to properties and uncheck "hidden" you will then be able to view the file and copy it to a flash drive or any other removable media, Microsoft do this for security reasons
Kind regards
Posted on Dec 23, 2008
I don't like .pst and .ost
First one you may check and apply methods below, to read articles and guides, to use manual, and finally only in case nothing of these appears ineffective, then take a look at ost pst conversion
Outlook Inbox Repair Tool (Scanpst.exe) is a utility that you can use in this case to repair your damaged archive.pst. It is highly recommended that you backup the damaged PST first as running the tool can irreparably damage the file.
• 1. Quit the application
• 2. Scanpst.exe is a hidden file so make sure that the 'Show hidden files and folders' setting is enabled in the folder options
• 3. Click Start ' Search, or Find and type 'Scanpst.exe' in the Search box
• 4. Double-click to open the file and browse to the location of your damaged archive.pst
• 5. Click 'Start' to start the recovery process
• 6. Try to open the file in question again. The corruption problem should not exist.
Sep 04, 2017 | Computers & Internet
Outlook file
You may apply solution below or make use of Recovery Toolbox for Outlook, application has many different variants, and is used for difficult cases.
1. Quit the application2. Scanpst.exe is a hidden file so make sure that the 'Show hidden files and folders' setting is enabled in the folder options3. Click Start ' Search, or Find and type 'Scanpst.exe' in the Search box4. Double-click to open the file and browse to the location of your damaged archive.pst5. Click 'Start' to start the recovery process6. Try to open the file in question again. The corruption problem should not exist.
Sep 10, 2016 | Computers & Internet
Complete Data Migration from Mac Entourage to Windows Outlook Need a solution for migrating all the data of Mac entourage 2008 over to Windows outlook 2010. I need a solution that is easy as I have...
You would need a third party solution to create a .pst file. You can export as .mbox file. This is a cross platform file format and you should be able to import into Outlook on Windows.
There are several tools that can do this. One is Entourge to Windows Outlook
The easiest option is to use an IMAP account for the transfer. Move the messages from your "On My Computer" folders to an IMAP account then add the IMAP account to Outlook on Windows and the messages will download.
Oct 07, 2013 | Microsoft Office Outlook 2010
Apple Mail Email Export
Having a google search can land you in a pool of solutions for your problem.
Or you can use applications to solve your issue.
There are various applications available for this problem. Have look at one I know:-
Apple Mail to PST Convert - Convert Apple Mail Emails to WIndows Outlook PST
Hope this helps
Thank you
May 26, 2013 | Computers & Internet
I lost my outlook contacts
if there was a probledm with your login profile then you can retrive data from old profile from below location
C:\Documents and Settings\\Local Settings\Application Data\Microsoft\Outlook\Outlook.pst
is thae user name with you log in
Local settings folder might be hidden . you can access the hiden fodlers by checking show hidden files & folders fro windows explorer > Tools > folder Option > View tab > show hidden files and folders
Jun 03, 2011 | Computers & Internet
Cant find my emails
If you were using Outlook and you mean you can not find your personal e-mails, try searching for Outlook personal folders using the Search function in Windows and looking for all *.*pst files on your hard drive.
This way you will be able to find any Outlook file containing archived e-mails.
May 17, 2011 | Computers & Internet
Outlook 2007 not starting. Error message says corrupted file. Run Scnpst.exe.
As an old Outlook user (for over a decade). I ever met similar error with my Outlook PST files before and got it solved with this Outlook PST repair software, the software extracts & restores those inaccessible Outlook items in a new .pst file and enables complete Outlook data recovery. If you want to take the most effective way, then try that program. Hope it helps too with your case.
Apr 12, 2010 | Computers & Internet
Outlook pst file creation and export
All your mail, your contacts, your calendars, and almost every other detail of your life is in Outlook. To make sure you don't lose all this in case of a hard disk crash or some other disaster, you can create backup copies of your Personal Folders (.pst) files — that's where Outlook stores all the essential data.
Back Up or Copy Your Outlook Mail, Contacts and Other Data To create a copy of your mail, contacts, calendar and other data in Outlook for backup or copying:
  • Go to your Outlook folder in Windows Explorer.
  • Highlight all files ending in ".pst".
    • Make sure in particular your selection includes "outlook.pst" and "archive.pst".
  • Select Edit | Copy from the menu to copy them.
  • Open the folder where you want to put your backup copies in Windows Explorer.
    • Ideally, this will be on another computer, on a removable disk stored far away from your home, somewhere on the Internet, or at least on a different hard disk.
  • Select Edit | Paste from the menu to paste your .pst files to the backup location
Restore from Your Outlook Backup Your backup copy of Outlook data is now in place, ready to be restored when you need it.
Restore Outlook Mail, Contacts and Other Data from a Backup To restore your mail, contacts and other data from a backup copy of an Outlook PST file:
  • Select File | Import and Export... from the menu in Outlook.
  • Select Import from another program or file.
  • Click Next.
  • Highlight Personal Folder File (PST).
  • Click Next again.
  • Now use the Browse button to select the backup copy of the PST file you want to recover from your backup location.
  • Make sure Replace duplicates with items imported is selected.
  • Click Next.
  • Finish the import process with Finish.
Usually, the default import settings work fine, but you may want to tweak them to suit your needs.
check this important link also where you can download a software to backup your outlook..
http://office.microsoft.com/en-us/outlook/HA010875321033.aspx
I hope you are satisfied with Fixya technical support.
It will be highly appreciated if you could take a minute and provide us your feedback..
May 07, 2008 | Microsoft Office Outlook 2003 for PC
Microsoft Office Outlook 2003 for PC Logo
82 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
