Question about Alesis M1-Active MkII Main / Stereo Speaker
Alesis M1 MKII bass ports
I have recently bought the M1's MKII (new) and installed them in my small studio. I've read in the manual that if your speakers are positioned next to a wall and/or a corner you need to plug the ports. I've put a piece of cloth in each port, which made the air sound through the ports go away. But when I put the volume of the speakers on 7 the bass will already distort. I don't think this is normal, because when I remove the cloth from the ports, I can put the volume louder without distorting the bass but then there is a very annoying  air sound hearable. Is there a solution for this problem or am I just asking way too much from my speakers? Should I plug the ports or leave them open? And with which material do I need to plug it? Thx in advance, Frederik.
  • frederik_goo Dec 23, 2008
    thx for yr fast response, the speakers are placed in corners but ofcourse with the front panel away from the wall. Is it normal that there is so much air noise through the ports?
  • 15,935 Answers
If desiring loud bass, keep port open. It is designed to be that way. If subs are in a corner, face the wall to change the wavelength and port noise wont be as evident.
Posted on Dec 23, 2008
  • blueextc3221
    blueextc3221 Dec 23, 2008
    there are complicated formulas you can use to figure out port noise. It's a give and take. The manufacturer is willing in this case to sacrifice a little port noise for a lower tuning frequency yet keeping the enclosure minimal. I believe the ratio is 3:1 port length to port diameter. If you want to slow down the air, put a breatheable material like grille cloth or fiberglass insulation. It will change the tuned frequency of the enclosure however.
    Ported enclosures handle more power more efficiently... so short of re-tuning the enclosure with a larger port, you are stuck with the noise.
  • blueextc3221
    Here is software that may help you in your quest....
    http://www.subwoofer-builder.com/flare-i...
Hi one of my alesis m1 520 speakers has a fault . it powers up ok but theres hardly any sound coming out . you can hear it but its very low
Try reversing cables between speakers just to make sure it's not cable or source. If it is a bad soaker, you'll need to contact Alesis for a local service center near you. Check w/ Guitar Center also, they have access to service.
Mar 10, 2011 | Alesis M1-Active MkII Main / Stereo...
Alesis M1 Active MKII Don't get power / Blue light is off
Sure they don't have power? Light breaks all the time on those things. If no power still, open it up and find out if there are any loose connections from the power leads. Bad power cable?
Mar 16, 2010 | Alesis M1-Active MkII Main / Stereo...
Question about replacing power supply (M1 active MKII)
The glue was most likely just to secure it in place. If you think it needs glueing in place then use a type that you think will hold it strongly in place.
The capacitors could have been given a higher rating for some reason, or it could be that the maker ran short of 220uf and fitted 330uf instead. To be honest I doubt if the extra 110uf makes a lot of difference. You could replace a 220uf with a 470uf one if you can get it in and it was the only one you had to replace a faulty one!
Feb 19, 2010 | Alesis M1-Active MkII Main / Stereo...
My alesis m1 active 620 monitors blue lite keeps blinking and duz not work
Thanks for following up...I took it to get fixed..$150.00 later it works..
Oct 04, 2009 | Alesis M1-Active MkII Main / Stereo...
Woofer not working
hi..
sounds like the voice coil could be open or damaged. the woofer can be reconed. reconing replaces all the moving parts in the speaker frame returning to new condition in most cases.
thank u
rate me
Jul 21, 2009 | Alesis M1-Active MkII Main / Stereo...
Woofer doesn't work
cathy@speakerex.com
Jun 25, 2009 | Alesis M1-Active MkII Main / Stereo...
Alesis M1 Active Mk2 Speaker won't Power Up
Hi, This is usually the Capacitor C8 on the powerboard it usually bulges and pops, its becuase its right next to a resistor which gets very hot and sometimes puts the capacitor into meltdown, yours might have gone past that stage but this is worth a look; http://www.neufeld.newton.ks.us/electronics/?p=232
Hope this helps
Cheers
Steve
Apr 14, 2009 | Alesis M1-Active MkII Main / Stereo...
Alesis 620 m1 active studio monitors sound cutting out
It could be a power problem, unless you have blown the driver ?, carefully pull out the power supply board, and look to see if anything looks melted, burned, or capacitors popped etc. Be carefull though as I do not want to be responsible if you get an electric shock, etc. preferably look and dont touch, just use common sense ;)
Feb 10, 2009 | Alesis M1-Active MkII Main / Stereo...
Need a M1Active MKII diagram
Hi, You will need to contact Alesis direct and they will decide whether to email you a copy of the schematics, as they are copyrighted, etc.
Dec 15, 2008 | Alesis M1-Active MkII Main / Stereo...
Alesis Monitor Problem
Hi Mate, Im no electrician so Im not 100%, basically I think it would last but it wouldnt be a long term fix as it really needs to be 105c.
Cheers
Mar 28, 2008 | Alesis M1-Active MkII Main / Stereo...
Alesis M1-Active MkII Main / Stereo Speaker Logo
544 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
