Question about Electrical Supplies
Heater wont shut off
May bedroom heater wont shut off. whats the problem?
    Sergeant:
  • 359 Answers
Thermostat stuck replace thermostat
Posted on Dec 23, 2008
The heater runs constantly, the thermostat seems to work, I check continuity through it, it opens and closes. What else could cause not to shut off?
QMark MUH (0521) Compact Heater Wont shut off ... - Fixya
www.fixya.com > ... > QMark > QMark MUH (0521) Compact Heater
QMark MUH (0521) Compact Heater, wont shut off related issues. Get free help, solutions & advice from top QMark experts.
QMark MUH (0521) Compact... Repair Questions - Fixya
www.fixya.com/support/p437492-qmark_muh_0521_compact_heater
Recent QMark MUH (0521) Compact Heater questions, problems & answers. ...thermostat on and contactor makes buzzing noise, fan dont run but its not seized it willfreewheel when you spin it ... How do I turn off my q mark wall heater there.
QMark MUH (0521) Compact Heater Shut - Questions - Fixya
Dec 01, 2015 | QMark MUH (0521) Compact Heater
Y does my glw-warm heater keep shutting off
Is this an unvented heater? They have oxygen depletion sensors which shut off the heater to prevent burning up all the oxygen in the room. Heaters over 10,000 btu's should not be used in small rooms like bedrooms and bathrooms. Other causes could be a dirty pilot orifice. Turn off the unit (so pilot is off) and use a can of compressed air with attached straw, to blow out any dust from the pilot assembly. (Where the pilot flame comes out). This will allow the pilot to burn a strong blue color and keep the thermocouple heated properly. If it's a thermostatically controlled heater, make sure your thermostat bulb is cleaned off regularly. Dust will insulate the bulb from sensing the room temp and will not operate properly. Hope this helps.
Mar 25, 2015 | Heating & Cooling
How to fill the water heater in a 2014 cougar 19rb
I have had two different travel trailers and both of the water shut offs were behind wood panels between the kitchen and the back bedroom
Jul 31, 2014 | Keystone 2014 Cougar Xlite 19RBE
220 appliances in house all out.lights up but either dont heat or wont bake .lightning could be culprit but never lost tv reception.dryer runs ,no heat.water heater out.stove lights up wont get hot.shut...
Sounds like you have lost one leg of your power
Think of it like this
You an upside down "Y" at the top of your breaker panel
220 - 240 volts come in the Y and break in half 120 volts to each leg of the "Y"
A 220 Volt breaker straddles both legs a 110 volt breaker only contacts one leg
I suspect that you have lost one leg
Possibly at the main breaker ( top most)( main disconnect) in your panel
If you have a tester with the capacity to test 240 you can test the two top lugs where the main wire comes in Test them together That is one probe of your tester on each wire you should show 240+/- volts
Then you can move down through the panel 120 +/- on each leg
Hope this helps if you need more just let me know
Scott
Mar 16, 2010 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
Kolin window type aircon shuts off by itself
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
Pilot wont stay lit
A short pilot flame not playing on the thermocouple or a faulty thermocouple , loose connection at the gas where thermocouple is ,
blocked pilot flame to small , air in gas line did he purge the gas line first? other wise you will be there a long time .
Dec 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Baseboard heater
the stat points are stuck together or the stat is defective. try tapping on it to make them loosen up or replace the thermostat.
Dec 08, 2008 | Fahrenheat FBE15002 Baseboard Heater
Wiring two heaters off the same 240amp power source
FIRST YOU MUST DASIEY CHAIN THE 12-2 FROM THE PANEL TO FIRST HEATER IN THE LINE AND THEN TO THE SECOND HEATER IN THE LINE, ENDS OF BOTH WIRES IN THE SAME END OF HEATER,BREAK ONE SIDE OF THE LINE THROUGH THE THERMOSTAT AND TO THE ELEMENT OF THE FIRST HEATER AND THE SAME FOR THE SECOND HEATER BUT IN THE FIRST HEATER YOU WIRE IN TH LINE THE 2-BLACK WIRES AND THE 2-WHITE WIRES WILL STAY CONNECTED WITH WIRE NUTS AND YOU WILL CONNECT THE THERMOSTAT WIRING UNDER THESE SAME WIRE NUTS AFTER YOU STRIP THE ENDS OF BOTH WIRES ENTERING AND EXITING THE FIRST HEATER TREAT EACH HEATER AS IF YOU WERE ONLY WIRING ONE HEATER ONLY DIFF 2-BLACK AND 2-WHITE WIRES STRIPED OUT AT FIRST HEATER IN LINE FROM PANEL TO ACCESS AND CONNECT FIRST HEATER ,BB HEAT 250 WATTS PER FT
Nov 11, 2008 | Electrical Supplies
Rinnai 556
money seems to be an issue for lots of us. but if you don't mind a coupla extra bucks get a few axial muffin fans and use them to spread out the heat pattern at your bedroom doors
Jan 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Electrical Supplies Logo
71 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
