Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Door seal how to replace door seal aqualtis
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Remove the front retainer, wire/spring affair.
slip the front of the seal off.
seal is held onto drum by a large sprung retainer, remove this by levering it off with a screwdriver.
put the new seal in and it's a case of putting the retainers back. the inside can be made easier with the application of some soapy water in the seals groove that the inner retainer sits in.
good luck as it can be easy or difficult doing the same job.
Posted on Jan 27, 2009
Aqualtis AC1 13DA 6971 Door does not lock
try leaning on the door when pressing start
Dec 26, 2015 | Hotpoint Washing Machines
How do i unlock the door manually it's locked with the washing inside
do you have the manual I found this answer but have no idea if your machine is like the one described .Then opened the door (if locked use yellow tab behind kicked panel to open
Feb 19, 2015 | Hotpoint Aqualtis AQXXL129PM Washer Front...
How to change noisy bearing on Ariston AQXXF 129
inner and outer drum has to b removed replace the bearing kit 2 bearings one oil seal as kit
Aug 25, 2014 | Ariston Technologies Washing Machines
The door of my washer hotpoint aqualtis won't close because the lock seems to be on. The washer cycles work fine but the door cannot be closed. What can I do?
The door lock is thermal, so simply switching off doesnt work.
Switch off at the power point for at least 10 min.
If still no good, replace the interlock.
May 25, 2014 | Washing Machines
My hotpoint aqualtis washing machine has started to smell following a wash cycle of domestic cleaning cloths. It completes a normal cycle. I have also checked the filter at the front and it is clear. Any...
Hi
Every 30 days is a good idea to use the 90deg wash cycle with just a towel in it with no detergents or use the descaling products available in the market with the 90 Deg hotwash. This problem also happens when always cold wash is used as detergent only really disolve well when the temp is 26 deg c or more.
There could also be mould in the machine which can be found round the bellow seals. IF it is present normally like dark spots and minor then they can be cleaned with methyl alcohol but if it is too many then the seal needs to be replaced. ALso after a wash wipe down the bellow seal with a dry cloth and keep the door slightly open for the internals to vent and dry.
Hope this helps.
Reynold
Dec 01, 2009 | Washing Machines
Hi I have an Ariston Aqualia front loader. It has
You could try mild solution of bleach to the drum, perhaps replace door boot seal..
Nov 04, 2009 | Vacuums
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Aqualtis washing machine door locked, need quick release?
yes there is a quick release
the door lock have 3 wires u should connect 2 of them together the first one and the third
but its dangerous if there is kids cause u will b able to open the door while its on
Jun 05, 2009 | Washing Machines
Hotpoint Aqualtis Stacking Kit
I Have the same machines and the only option is the Hotpoint stacking kit. Available from Hotpoint - 08448225225. They are selling it half price at the moment for around £70 delivered. I have been assured by Hotpoint this is the only option.
Mar 01, 2009 | Silver King Stacking Kit For SKR27 and...
A hotpoint aqualtis aqxx149pm spinning loudly
Hi, This is a common problem with the hotpoint range. It will be the main wash bearings that have failed and need replacing. This is a very easy process but is quite time consuming. Remember tho change everything that is; Bearings, and bearing spider and front tub seal as you dont want to have to do it again in a short time or have leaks coming from the front.
Good luck and get back to me if you need any further help....................
Jan 02, 2009 | Washing Machines
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
329 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
