Question about BenQ T701 TFT 17" LCD Monitor
Tech problem Hi, my firend was given a Benq t701 monitor. After he installed it, he turned on the computer. The DOS page stayed on for about ten minutes, then it installed windows, but all he could see was the wallpaper. All the icons as well as the start menu and everything else had disappeared. He tried restatrting it, same problem. He went back to his old monitor and the problem stayed... What can he do?
  • BenQ Master
  • 855 Answers
If you can, check the display settings.
Some graphics cards have an option for dual monitors.
Sounds like the card is seeing only 'monitor 2'.
If you have more than one monitor port, try plugging both monitors in.
If no luck, you may have to boot into BIOS at power-up and configure from the menu.
But be careful not to fiddle with unknown settings in BIOS - this is the 'nerve center' of the computer and could cause total digital catastrophe.
If not sure, don't.
Or get expert to help re-configure.
Posted on Dec 20, 2017
djnupi
  • 26 Answers
SOURCE: benq t701 flat screen no display
see this post
http://www.fixya.com/support/t155971-benq_t701_lcd_monitor
Posted on Dec 16, 2007
SOURCE: BenQ FP731 Screen briefly displays then turns off
Did an independent diagnosis before finding this, and came to same conclusion. First found fuse PF751 was open circuit (3A black plastic fuse, not glass) over close to main heat sinks. When I replaced that with a fine fine strand of wire (for testing) then I saw Q759 (C5707) get hot. Checking the others shows that they should be driving into about 420 ohms on the primary side of the transformer for the flourescent lights (backlights) but on this one it was less than 1ohm. I've unsoldered the Q759 and now I measure 420ohms here too. Now I need to find a new C5707 or equivalent...
Posted on May 17, 2008
SOURCE: Benq T701 Monitor not display
the video converter is brock
Posted on Sep 09, 2008
SOURCE: Benq monitor flashes primary colours when switch on or off
This is called burn-in mode. Used to test the monitor at the factory.
To fix this, use the buttons under the front of the monitor,
There are six buttons. Let's number them 1 to 6 from the left.
Press 6 to display menu (at the bottom in Red will say Burn in mode on)
Press 4 or 5 until Recall is highlighted
Press 6 to select
Press 4 or 5 until Recall All is highlighted
Press 6 to select
Press 4 or 5 until Yes is highlighted
Press 6 to select
Press 3 to exit
This will reset all paramaters and also turn-off burn-in mode
If you want to reset some parameters to your preferences, press 6 again to bring up menu and
see you user guide to get explanations for the different settings.
Posted on Dec 29, 2008
SOURCE: Benq T701 LCD monitor
I had a similar problem: the backlight on my Benq T701 only functioned for a couple of seconds every time a turned the monitor on and then the backlight switched off (sometimes in two stages). An electronics guru at work said with those symptoms the transistors rarely were the problem and I just needed to resolder the connections of the high voltage coils onto the PCB. On visual inspection those solder connections seemed ok, but when I tried to reflow the existing solder at one connection I spotted the problem: just a thin surface layer of solder was present and I had to add solder to fix the problem. The 4 coils each have 6 leads on one side and 2 on the other. I only soldered the connections on the side with 2 leads. In just 30 minutes and without buying parts the monitor is now up and running again.
Posted on Jan 22, 2009
When turning on the monitor it reads non preset mode
Go to menu and set it to factory default.Thank you.
Sep 16, 2011 | BenQ T701 TFT 17" LCD Monitor
I brought my benq t701 to a repair shop to due blackout screen. But due to lack of parts, it was not repaired but all 6 transistors were removed from the PCB. Please show me where these transistors were...
go to esservice.com and get the manual from there will be easier as the transistors are directional i believe they are 2sc5707s from memory but you will need to check the transformers and the 2 filter caps on either side of them as if they are faulty will blow transistors.
Dec 30, 2009 | BenQ T701 TFT 17" LCD Monitor
I have a benq t701 with power problems
faulty power board... possibly caused by blown capacitors..
Jul 03, 2009 | BenQ T701 TFT 17" LCD Monitor
Benq fp767 backlight problem
I've repaired my FP767 just today. It had similar problem.
First of all I thought that I needed to replace CCFL tubes.
Then I noticed inflated capacitors in power supply.
I replaced them all and monitor works as new.
Apr 24, 2008 | BenQ T701 TFT 17" LCD Monitor
Jun 23, 2007 | BenQ T701 TFT 17" LCD Monitor
Benq t701 flat screen no display
see this post
Apr 15, 2007 | BenQ T701 TFT 17" LCD Monitor
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
BenQ T701 TFT 17" LCD Monitor Logo
121 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
