Question about Acer AL1714 17" LCD Monitor
AL1714--Substitute Power Adapter w/slightly higher voltage ??
Hi! My adapter went south! (Monitor was flashing green light and no response to any buttons). Can I sub an adapter with a slightly higher voltage (e.g., 20v--Dell AC-6 series adapter, or Targus 18-24v adapter) without damaging the monitor? Thanks, Mark
KW: Acer LCD Blinking Flashing Blinks Flashes Blink Flash 1714 AL1714
SOURCE: Acer AL1714 17" LCD Monitor Good Power supply no power on monitor
Hello, I have to same problem. I returned my monitor to Acer but got it back unrepaired, they could not see the malfunction. But I kept on sending it back, until I got a new model. Now after 2 years I get the same thing with this monitor. But there's no warranty anymore, so I looked into the problem myself. I found out that inside the powercircuit board is connected to the mainboard through a 10pin connector. The 5 pins that are on the lowest row, show a trace of white powder, I suppose occidation. I sprayed a little of contactspray in it. I must say the problem is not gone, but much better. The problem shows not so frequent anymore and lasts not so long. At first the screen switched of for 3 to 5 minutes and came back on. Now the screen is gone for perhaps 1 second and returns. So I'm almost convinced the problem has something to do with the connection of the powercircuitboard inside and the mainboard inside, when the monitor heats up a bad connection occurs due to occidation of the 10 pin connector. If you find a solution that fixes the problem 100% let me know, please. Mario.
Posted on Apr 29, 2007
SOURCE: Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Posted on Aug 22, 2008
Fix-4U
  • 293 Answers
SOURCE: ACER AL 1714 SM MONITOR
Hi...there,
Well...your backlight inverter are busted.... need replaced a new one or repaired it.
Posted on Oct 12, 2008
Fix-4U
  • 293 Answers
SOURCE: Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Posted on Dec 18, 2008
  • 40 Answers
SOURCE: need a power suply for a acer monitor model
Many laptop adapters are 19v.
Posted on Mar 27, 2009
On 9/11/12 I purchased a NEW battery for my Acer Aspire 3000. When the battery was installed at work the laptop worked for 5 hours at work. I shut it down n went home. Where it stopped working.
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 12, 2012 | Computers & Internet
Hi i have a siemens amilo pro v2035 laptop its not powerong on i opened the laptop and saw something burned next to the dc port i soldered it but it still deosnt work
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.
May 01, 2011 | Fujitsu Siemens AMILO Pro V2010 Notebook
My Acer Aspire 4530 Laptop Charger in not working properly charger green light very dim when charger connect the laptop. but not charge the laptop.
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Feb 25, 2011 | Computers & Internet
No power response, replaced battery and charger still no power
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jan 31, 2011 | Acer Aspire 4720 Notebook
My laptop charger isnt working! it was working like 15 minutes ago! but now its not working properly. the green light was off yet it was charging
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Dec 16, 2009 | HP Pavilion dv4000 Notebook
Screen just went blank. Power light will come on but nothing will show up. Every person I take it to tells me something different. One man told me the motherboard went out and another told me it was...
If the power light does not come on when you plug in the power adapter then it maybe faulty or the power socket on the laptop maybe faulty.
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 21, 2009 | Acer Aspire 3680 Laptop
My Inspiron 9400 started going off and all the lights would go off with the ac power cordYou could wiggle the cord which connects in the back a little and sometimes the green light would come on. The AC...
You could have a power adapter problem, the adapter usually quite warm to touch but not very hot.
Oct 08, 2009 | Dell Inspiron 9400 Notebook
I tried to switch on my laptop and it started booting and suddenly went off.From then on its not even booting.Nor does it show the green light which comes on, when you plug it to a power source. Its...
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
A faulty adapter or the connector is not making proper electrical contact, this causes the LED not to illuminate. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
May 09, 2009 | Lenovo R61 T7300 Notebook
Power cord
This one should do the trick.
http://insidecomputer.stores.yahoo.net/ac-adapter-for-acer-al1714-al1714b19volt-l1714171419.html
Feb 09, 2009 | Computers & Internet
Power issue with LCD Monitor
Try another power adaptor. Check the delivered voltage and go get a universal power adaptor that has a switched for varios voltages and a number of connectors. Simply match connector to the voltage switch.
May 21, 2007 | Princeton Digital LCD17 17" Flat Panel LCD...
Acer AL1714 17" LCD Monitor Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
