Question about Dell Dimension 2400 PC Desktop
CPU will not start up
We have everything plugged in, but the DELL button will not turn amber to green and begin the startup process. There is no activity from the hard drive light or the fans.
  • 1 more comment
  • robkinney1 Dec 23, 2008
    There is no power on the keyboard and when I hit the startup button, nothing happens. No lights or fans, only and dim amber light.
    I am thinking it may be the powersupply because the fan doesn't even turn on.
  • Dan rogers
    Dan rogers May 11, 2010
    if the computer sits and the button is amber that usually means that the computer is in sleep mode and a keystroke or mouse click will wake the computer up. Try to turn the computer all the way off. (usually unplug or switch off the power supply) then try to boot the computer again and tell us what happens
    Master:
  • 413 Answers
Also make sure the CPU is installed all the way. There have been a couple people with the same problem so it might not be a bad idea to contact dell and see if they had a bad batch of computers go out.
Posted on Dec 23, 2008
  • Dan rogers
    Dan rogers Dec 23, 2008
    also another thought is to check and make sure you are getting adequate power from the outlet. It wouldn't be fun to go through all this and find out you just need to replace an outlet.
  • Dell Master
  • 4,806 Answers
Hi there
Do you get a post screen at all?
If not chances are that there is a problem with the power suppy, check that all the connections are well seated on the motherboard (inside the case), also check that all the connections and leads are well seated and that the memory is seated well too
regards
  • Lee Hodgson
    Lee Hodgson Dec 23, 2008
    sorry you misunderstood me, you have to take a look inside the computer case itself by removing the side panels
  • Lee Hodgson
    Hi again
    I have work with many dells, they tend to use their own power supplies and they do fail occasionally. 90% of the motherboards are not affected by the failure and you will probably just have to replace that and the computer should start up again
Hp pavilion slimline power supply
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
May 23, 2017 | Computers & Internet
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
My dell xps 400 was shutting off and all i was getting was a solid amber light in front. I was able to hold it in for a bit and then press it and turn it back on for about 2 weeks now. It finally shut off...
You more likely had a temperature issue with the CPU.
Had the CPU fan started to sound like an airplane warming up?
If so, you may have finally burned out the CPU.
Yes it's possible that it was reporting a problem with the power supply, but the only way to know for sure is to replace it.
In the meantime, eliminate everything else.
Disconnect power from EVERYTHING except the motherboard.
If it powers up, then it's possible that either your motherboard is failing (and now works under the decreased load), or one of the things you unplugged has failed.
If the unit springs to life, turn it off, and start reconnecting things.
If it fails constantly whenever 1 specific thing is plugged in, that thing or the motherboard chip that controls it is the problem.
Mar 12, 2011 | Dell XPS 400 PC Desktop
Take a 2-CPU Precision 670 down to 1-CPU
You probably removed the "primary" CPU,
and the computer cannot operate only with the "secondary" CPU installed.
Move the CPU from the "secondary" slot to the "primary" slot.
Jan 13, 2010 | Dell Precision Workstation 670 PC Desktop
Dell Dimension 8300 power light flashes amber. Watched a move on it last night from an external hard drive, after which i shut down the computer eg start, turn off comp, turn off. It carried on installing...
Hi damos_turbo,
I wish I better news for you, but your going to be going into PC hell. What the amber light is telling you is that something on inside the case is bad. It could be the CPU, or the motherboard, or the PSU.
I would give you my normal advice with dealing with MO's but with the Dell 8300, it has a life of it's own.
Determining was is broken is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a dead Board. As I said in the beginning, PC hell is here.
I sometimes just advise people to get a new computer, If you like dell's they have new ones for $300.00 to not only match what you have, but will have a whole lot more speed.
Good Luck and don't forget to leave a rating.
Thanks
Mark
Dec 10, 2009 | Dell Computers & Internet
Only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
Dec 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Dell Dimension 2400 PC Desktop Logo
61 people viewed this question
Clive
Clive
Alun Cox
