Laptop wont connect to power supply
We have to Gateway ML5227b laptops. My sons was the first to stop working......at first it was as if the connections were loose, then finally gave up working. He used to swap batteries with my laptop and i'd charge his up while he used my battery, so I know its not the batteries. Then mine went, again like my sons, on and off at first as if the connections were loose then just stopped charging altogether.
I cant afford to take it to a shop to get fixed.
Please help
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    do the laptops work on AC power?
    Scholar:
  • 73 Answers
Sorry to say it, but the charging port in your laptop may be loose. The "loose" feeling that is often described is because one solder joint comes loose, so by moving it around it will reconnect. Unfortunately, doing this also causes the other joints to come loose, and they will eventually break off too. If (and ONLY if) you have experience soldering with electronics, you can open the case of the laptop, and attempt to resolder the port back onto the motherboard. Even if this does work, however, the solder that is generally available to consumers is a lot weaker than commercial grade solder, so the joint will be weaker than it was before.
The better solution would be to find somebody with experience with this, preferably a friend that won't charge you, or take it into a shop to get fixed. Make sure you get a price estimate, though, as this can be a fairly time consuming process.
Posted on Dec 23, 2008
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
Problems with Gateway MX6447 PC Notebook? wont turn on
Unplug the battery and the power cable from the laptop
Now press and hold the power button for 20sec(no battery and no powercable)
connect the power cable back to laptop
Now turn on your computer
Hope it will work!!!!!!!!!
Varghese Joseph
N/W engg
Nov 25, 2009 | Gateway MX6447 Notebook
Power Problem with A/C adaptor on my Gateway M-6816. The light on the a/c adaptor flashes green and the laptop wont charge. This is a new factory a/c cord.
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 17, 2009 | Gateway M-6816 PC Notebook
Wanting to disconnect laptop screen
it would be simpler just to use a usb keyboard and mouse and just use it as a desktop computer
Aug 01, 2009 | Computers & Internet
Gateway laptop no power. Working ok last night checked power supply pack all ok 19v coming through But wont power laptop help
Remove the battery and try to power it. if this fail, them change the memory and then the processor if this also fail then one of the power chips on board is bad (also check the power connector if is not soldered properly.
Jul 01, 2009 | Computers & Internet
Gateway Laptop it not powering with or battery or plugged in
Try to connect AC/DC power supply to your PC. If it works there is something wrong with your DC Battery. If you have done this, try to use tester to test if the power battery can still transmit power from source. If power is down, may be another kind of battery that is compatible to your PC. Insert only battery required for your laptop that would destroy your PC totally.
Jun 19, 2009 | Gateway Computers & Internet
Gateway MT6840 Laptop will not power up
have you already tried to power up your laptop without the battery, only with the powersupply docked in?
If this works, you´ll have to replace the battery or use the laptop without a battery.
If this doesn´t work, just take the full battery from the other laptop try to power up the laptop without the power supply docked in.
If this works, your latop motherboard is broken and till it is replaced, you have only the chance to work with a battery and reload it with another latop.
Jun 02, 2009 | Gateway MT6840 Notebook
I'm trying to fix a gateway MFATXNIN NMZ 500SE
Check the adapter with a multi-meter to see if there is voltage at the plug that connects into the laptop. The oltage reading should be slightly higher than the voltage that is printed on the label on the adapter.
Try to borrow an adapter (same as yours) and connect it to your laptop. Also try removing the battery and power up the laptop without the battery but with the adapter connected (could be a battery problem).
Mar 29, 2009 | Gateway NMZ-500SE Notebook
Gateway Laptop overheated and stopped working.
Usually when the laptop overheats the CPU shuts down, and after it cools down you may be able to power it up again, unless the CPU has failed.
If you are able to get the laptop working, get the fan replaced, if it laptop doesn't boot up then there is a serious problem (most likely a costly one).
Jan 01, 2009 | Gateway Computers & Internet
Gateway laptop wont connect to power
The only thing you can really do in this case is call gateway and see if they can repair this. it seems like something internal. Hopefully the computers are still under warranty. Sorry for the bad news.
Dec 23, 2008 | Computers & Internet
Computers & Internet Logo
117 people viewed this question
Alun Cox
David Payne
David Payne
