Question about ViewSonic - PROJECTORS - PJ452 1500 LUMEN XGA MMPROJ LCD 10X7 4.9 LBS Multimedia Projector
Viewsonic pj 452
When im watch my projector a square pop up that says check the air flow.........I dont know what to do?
You may need to purchase a new AIR-FILTER, but try this -
What you have to do ... on te remonte control click the MENU button:
Next scroll down to the Filter option and hold down the RESET button on the remote control until a wondow pops up asking you to reset. This should fix your problem, if this doesn't than purchase a new AIR-FILTER remove the old one and install the new filter; then try to reset it again.
I hope this was helpful.
Posted on Jan 08, 2009
PJD 5111 Viewsonic projector shuts down after 10minutes?
Hi! I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 20, 2011 | ViewSonic PJD5111 Projector
Where is the air filter on the Hitachi pj-tx10? I dont know how it looks?
it's on the right hand side of the projector when you are looking at the projector from the front. The plastic grille just unclips and the filter is inside.
Mar 30, 2011 | Hitachi PJ-TX10 Multimedia Projector
My Viewsonic PJ 500 projecter light is not turning on. "lamp" light is blinking.
That means that the bulb is bad and beeds to be replace, This usually happens after 1000 hours of use.
Aug 28, 2010 | ViewSonic PJ500 Multimedia Projector
Our PJ-TX10 projector is turning itself off
First, to rule out true overheating, clean any dust filters and air-access areas. There might be enough dust on the filter to cause a gradual build-up of heat which could trip one of the temperature sensors in the unit. I clean my projector once a week--There might be a cooling fan going bad--after a while, heat causes the fan motor to start to drag and slows down the air flow. Also, there might be a temp sensor that is shutting down the unit prematurely.--Rick
Sep 06, 2009 | Hitachi PJ-TX10 Multimedia Projector
New ViewSonic PJ 513DB connected to laptop. Cannot see DVD
I think this is your laptops problem with putting out that on both displays at the same time try cloning or playing with those settings
Mar 07, 2009 | ViewSonic Office Equipment & Supplies
Dvd player to projector
Yes please.
You can connect it either thru the RCA Composite output(yellow) of your DVD or thru the S-Video or even thru the component out(YPbPR) connections. In the component out you would require three RCA cables and would give you the best possible picture.
Find a link below , which gives a review of the Viewsonic PJ 501.
http://reviews.cnet.com/home-theater-projectors/viewsonic-pj501/4505-7858_7-20722971.html
Hope this clarfies.
Please do rate this solution and thanks for using FixYa!
Mar 04, 2009 | ViewSonic PJ501 Multimedia Projector
Hitachi PJ-TX10 alligment
i have one of these projectors found on setting it up that the projector must be square on with the screen, the pjtx10 doesn't have ant "wedge type" setting like sony does. if this doesn't fix problem there is some thing not aligned in the lense
Mar 04, 2008 | Hitachi PJ-TX10 Multimedia Projector
Open Questions:
See all ViewSonic - PROJECTORS - PJ452 1500 LUMEN XGA Questions
ViewSonic - PROJECTORS - PJ452 1500 LUMEN XGA MMPROJ LCD 10X7 4.9 LBS Multimedia Projector Logo
346 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
