When i turn on my 360 it makes a clack sound and 3 red lights on the front start to flash. HELP ME!!!!!!
Comment by Dstryr320, posted on May 18, 2007
PEACE
gamertag Dstryr320
736 Other Users Have The Same Problem
Comment by Guest, posted on Jul 21, 2008
I got this problem too, it means that the GPU and the CPU have failed.
Here
is an article that will explain what happens and it also gives you a
few tips to fix it for good and make sue it doesn;t happen again:
Xbox 360 3 Red Lights Fix Tips
Comment by julinels, posted on Jul 21, 2008
My xbox 360 has 3 flashing red lights when I turn it on and then it does nothing. Cant play anything on it. Please help me!!!!!!
when i turn on my xbox 360 three red light turn on what should i do please help
Comment by clementinoz, posted on Jul 21, 2008
Flashing red lights on the power button when I turn on xbox console.
Comment by Guest, posted on Jul 20, 2008
jjj
Was this solution helpful? Show your Appreciation by rating it:
Its a fatal error with 360s, and theres not a thing you can do about it.
It takes days to months once sent in to replace, but its 100% free.
Rating: 0%, 0 votes
Image1:
Comment by Carl26, posted on May 01, 2007
If it still doesn't work properly, wait 20 minutes with the console still turned on. After 20 minutes, turn off the console, wait 2 minutes for it to cool down and then turn it on again. It should work. This solution was tested on the error 0102 also known as the three lights of death...
The specific type of hardware failure can be determined by a "hidden" error code
* Turn the xbox 360 on, and wait till the 3 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code (as described below).
* Release the eject button and press it again.
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
* All four lights flashing - 0
* One light flashing - 1
* Two Lights flashing - 2
* Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
0023 (not yet known)
0101 (not yet known)
0102 unknown error
* though it's most likely GPU related literally means the console does not know what is wrong. possibly a short or cold solder joint somewhere. So far there is 1 major theory for what causes most of these errors is that the Ram, CPU, or GPU are not soldered properly to the mother board due either to poor manufacturing or excessive heat up and cool down cycles that stress, weaken and eventually break the soldered connection.
There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced. I have also heard of limited success by simply switching the AV cable from "HDTV" mode to "TV" mode.
0103 CPU Error/ CPU Overheating - see solution for error 0102
0110 Memory Error / Memory Overheating - see solution for error 0102
0200 (not yet known)
1000 (not yet known)
1001 (not yet known)
1002 (not yet known)
1003 Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
1010 Hard Drive Error, Can be caused buy a corrupt or missing eProm.
1011 (not yet known)
1012 (not yet known)
1013 (not yet known) possibly a dashboard update error
1020 (not yet known)
1021 (not yet known)
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
1023 DVD drive not connected, connect DVD drive to boot
1030 (not yet known)
1031 (not yet known)
1032 (not yet known)
1033 (not yet known)
1444 and up There is no "4" in the error codes four lights is a "0" go back and check your code again.
--==Console Reset Codes==--
Clear All Installed Game Updates and Console Cache
1. Go to the "system" blade
2. Select "memory"
3. Press Y on the HD symbol
4. Press X,X, Left Bumper, Right Bumper, X,X
5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
6. Select Yes
Clear Any Failed system updates that cause the console to error.
1. With the console off, press and hold the sync up button (the small white one)
2. While holding the sync button press the power button to turn on the console
3. Continue to hold the sync button until the Console has booted up completely.
4. During the boot process the console should clear any failed updates, allowing you to use it normally.
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Microsoft are now accepting liability for the 3 red lights issue.
My childrens XBox warranty had just expired (2 weeks prior). I was about to commence on the rubber thing, but thought i would phone customer services anyway to complain about the problem and the sheer number of people that this has happened to. They are now giving a full 3 year warranty for this problem and have collected the XBox this afternoon.
Hopefully they will fix this with a new design that prevents this from reoccuring. Anyone who has had this fixed can also claim the repair bill back if within 3 years.
contact customer services on 0800-587-1102! uk.
Playing Naruto for about 3 hrs now, looks promising. I'll check for better ram cooling stuff for any further red lights to come. Thanks for the information. Made me happy today.
6. Return it...... the only thing that they will mostly look at is the bar code in the back and the rest of the merchandice in the box
I know this seems like alot of work but it isnt and it saves you money in the end with a brand new updated 360 Enjoy :)
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Rating: 0%, 0 votes
What it is basically trying to do is overheat the console to the point where the poorly soldered connection ( that has come apart and is causing the lights'o'death ) melt again and hopefully re-establish contact, forming a proper connection again.
Apart from the fact that it is retarded you are also going to be overheating all the other components in the 360 that are otherwise working i.e GPU.
Please do not use this trick. Call MS and have them replace the console.
Rating: 0%, 0 votes
1- i but a rubber ereser in the bottom ram
2- i but a cooper heatsink over the GPU ram
3- i leave the top case open.
4- i add one fan over the cpu heatsink.
that it now the xbox 360 are not hot at all. thanks
Rating: 0%, 0 votes
Basicly, as the Xbox heats and cools from use, the solder holding CPU and GPU onto the motherboard cracks, and the chips no longer make a connection. This is why the how towel method seems to work - by overheating the xbox the solder expands to remake the contact. As soon as it cools again, the solder shrinks back and the connection breaks again.
The hot towel method however severely stresses componants and should never be used.
My fix went like this - strip the xbox, and remove the heatsinks.
Toss away the x-shaped springs that held the heatsinks on.
Remove the bolts from the heatsinks. Drill out the fins that cover the bolt holes on the GPU heatsink.
I then used PC motherboard risers and screws to bolt the heatsinks directly to the Xbox mobo, much MUCH tighter than originally designed. This forces the broken solder contacts back together, even when the xbox is cold.
Since doing this my Xbox had started up no problems every time, however, it is a hack job, if you want to use this method be very carefull, tighten the screws to much can split your xbox motherboard and destroy it!
Good Luck!
Rating: 0%, 0 votes
Now im gaming better than before!!!!!
Thanks fellas it was easy!!!
Rating: 0%, 0 votes
1. 6 rubbers ( rubber method didnt work )
2. Alaska thermal compound( coolant gel applied to micro chips and did nothing )
Other methods we tried ( and didn't work )
1. Loosen the X clamp screws
2. Cut out bigger holes for the fans ( maybe worked it made it cooler? )
3. Alloy heatsink ( again not sure might just make it cooler)
In the end we used the towel method were you leave your xbox on while it is wrapped it towels allowing it to overheat and re-attach the soldering ( which by the way was a major fault for microsoft manufacturing ) It has been working for about 2 hours now PERFECTLY but I must warn you please try the above things before you attempt the towel method because it is VERY RISKY as it can melt precious components and then you've not only killed the xbox but you've given it a cremation so like I said USE THIS AS A LAST RESORT AND WHEN YOUR FEELING BRAVE!!!!
Comment by Dinoza, posted on Aug 24, 2007
Rating: 0%, 0 votes
Rating: 0%, 0 votes
before i had error code 0102, but now it is 0020 which is apparently overheating issue?
gonna try puting a massive fan on it, even though id already upgraded the itnernal fan to a better cooler.
also trying the leaving it on for 20 mins then trying again method.......maybe it will work....hope so.
anyways, thanks for giving me a week of xbox at least :)
-x-x-x-
Rating: 0%, 0 votes
