Question about GE Dryers
Need wiring diagram for GE electric motor
I have a GE 110v, 1/3HP, 1725 RPM, code T motor removed from service, from a dryer I think. The part no. isĀ 5KH42CT80AS
Can I get a wiring diagram for it?
Benimur
  • 6966 Answers
SOURCE: need a wireing diagram for
Often the wiring diagram maybe found in the console area or under the dryer top panel. Due to regional differences in electrical code and power requirement, wiring system hence the diagram may differ. Additionally, it would also differ if you are using a 4 wire outlet or a 3 wire hookup.
At this point, perhaps your best bet would be to seek the services of a qualified professional who is very familiar with the electrical/power system of your area as well as general wiring of dryers. Should you venture a DIY, pls post back power requirements/availability whether for a 240/120 or 110/110.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jun 17, 2008
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
dragonsthatk
  • 547 Answers
SOURCE: need schematic for replacement motor GE dryer model DDE6350GALWH
http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
michaelcanto
  • 76 Answers
SOURCE: need a wiring diagram for a maytag gas dryer dg312
If the old motor is still installed simply change wire for wire.
Posted on Jul 27, 2009
reverendrave
  • 24 Answers
SOURCE: Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Posted on Sep 17, 2009
My a.c. in my rv will not come on it has 110v but I guess it is not getting 12v needed to make t stat work. I skinned they stat wires on what I think is the blower motor and the 12v but didn't even get an...
There's this website www.reliable-store.com
They have books on ALL vehicles.
it covers wiring diagrams,
electrical diagrams, fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
Mar 18, 2018 | Cars & Trucks
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 | GE Dryers
How to reverse rotation of single phase, 1/2 HP, 110V electric motor.
Changing the "polarity" of the start winding by swapping the wires over should reverse the direction. Lots of online motor-related generic and manufacturer information is available.
Feb 16, 2015 | Air Tools & Compressors
How to change Emglo air compressor from 220v to 110v. Compressor is running at half speed when plugged into standard wall outlet. I bought the compressor new in the early "90's" and since then...
Hi Pete,
On the side of the motor on the label should be a wiring diagram. The diagram will tell you how to wire fro high 220v and low 110v ...
If the nameplate is single voltage only then the motor cannot be rewired for the lower voltage...
Also check the motor RPM nameplate as compared to the others...you may have a 1725 motor and the newer ones a 3450 motor...that would give them double the RPM's if the gearing or pulley sizes are the same...so.. if you have the right voltage and the RPM's of the motor are the lower, then you possibly could change the pulley sizes to speed up the compressor...
Lots to check and think about...
heatman101
Mar 11, 2011 | Dewalt Air Tools & Compressors
AO smith compressor motor missing toggle for duel voltage
Most motors will have a wiring diagram on them with numbers not colors, and show the wiring configurations for both voltages. If you do not have this then you may want to contact a motor shop and see if they can get it wired for you.
Nov 25, 2009 | AO Smith Air Tools & Compressors
Need a ge motor 1/3 hp 1725 rpm for a toledo commercial slicer or why does motor will not start until you spin shaft?
check motors bearings for oil ports try to lube first before replacing-common motor -appliance parts-online parts-catalog(grainger)or other hvac-plumbing-heating stores
Nov 04, 2009 | Kitchen Appliances - Others
Wiring diagram for electric motor Sole made in Hungary Model 205850 AC EL CL F 110V 16K RPM 110 volt"
The more I look at this motor the more I think that it is a stepping motor and not an AC motor... I could be wrong, but checking the windings and seeing the small Tach Motor on the rear leads me to believe that this is not a ac motor, but a stepping motor and is triggered from the programmer for rpm
Apr 30, 2009 | Washing Machines
I need to wire a 2HP 110V ge motor to 220V
I think the only place you will get this info is from GE -- and good luck with that.
Apr 29, 2009 | Dryers
Wiring diagram?
They ain't power leads. They carry heat element current from the cent sw when the motor is running.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 10, 2009 | Dryers
Dryers Logo
241 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
