Question about Bosch Axxis WTA 3510 Electric Dryer
Dryer Struggles to Start Tumbling WTA3510 UC/13
Benimur, Did you loose your account and have to set up a new one? If not, There is a guy (blueextc3221) claiming to be you. Anyway I would like to accept your solution for my dryer problem. Please repost if you can.
Thanks,
Thomas
  • Thomas Landon Dec 23, 2008
    I didn't think it was you. Thanks for responding. I'll wait for contact from FixYa before proceeding any further
    Brigadier General:
  • 6,966 Answers
Hi again Thomas,
Thank you for your concern. And no, I did not loose my account. It is just the way the system goes. As coldhourz has posted, I have done multiple repost but for some reason, you could not view any of them.
I have emailed the admins of the status of your post/problem. It is just that the wheels do grind a bit slowly. With your indulgence, may I suggest that we leave things as they are and just not to please accept any new solutions. I would expect that you would receive an email detailing how to go about accepting my solution.
Pls bear with us as things are being attended to even now as I respond to you. This much I know as I received an email in response to my calling the admin's attention. Again, might be some more delay(s) but what is important is that you know I have not abandoned your problem with just a single post.
Again, thanks. The FixYa rating would be secondary as your acceptance is more important.
Posted on Dec 23, 2008
Admiral Heavy Duty Super Capacity Plus dryer does not start when button is pushed. The dryer buzzes when the start button is pushed, but the dryer will not start tumbling. The model number is ADE7005AYW...
Motor runs, but drum does not turn
1. Broken or slipping belt---replace
2. Loose pulley---tighten pulley on shaft
3. Drum jammed or bearing frozen---check for foreign object & clear it
Clean or replace bearing
Sep 21, 2011 | Dryers
Trouble with starter motor struggles to start in
Check battery cables and all cables on starter for loose connections. Look for corroded cables and don't forget to inspect the ground connection. Check voltage at starter with key off and while cranking if possible. Voltage shouldn't drop below 10V if all is well. Diesel vehicles usually have a higher torque starter, maybe gear reduction. Depending on age of vehicle, could be worn out. If you're a DIY guy, remove it and take it to your auto parts store for testing.
Jun 30, 2010 | 1997 Isuzu Rodeo
Dryer not tumbling heat but no tumble
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Apr 19, 2010 | Bosch Classixx WVF 240S Front Load Washer...
GAS DRYER TUMBLING ,BUT NO HEAT.
Most of the later model dryers have electric ignitors, sounds like you have a ignitior, that is burnt out.
Take the brand, model and serial numbers to a appliance parts store to get the part.
If this has been helpful, please rate the new guy :)
If I can help you any more, just give me a shout.
Sincerely,
Paul Gibson
Apr 05, 2010 | Goodman GMS90703BXA Heater
Dryer will not start up.
you have a bad motor or something is stuck in the blower housing connected to motor
Sep 15, 2009 | Dryers
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Maytag dryer model#PYE2300AYW turns on but makes loud noise when tumbling. whats wrong with it?
If it is a metallic noise, it can either be a pulley with bad bearings, or possibly the rear drum support/ bearing. If squeeling noise, possile belt. I would open the unit and check it out. Keep in mind that, in many cases, the repair can be more than buying a new unit. I bought a good, new dryer from Lowes for around $200. It would be hard to get a repair guy to come out and do the repair for that amount. Choose wisely grasshopper.
May 08, 2009 | Maytag PYE2300AY Electric Dryer
Tumbling bar is loose and getting looser
youll need to lift the top of the unit, and and form there youll gain acees to the outside of the drum assembly, the "tumbler bars" are secured by 5/16 screws from the outside ofthe drum assy
Feb 12, 2009 | Maytag MDG7600AW Gas Dryer
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Bosch Axxis WTA 3510 Electric Dryer Logo
184 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
