Question about JVC HD-52G786 52" Rear Projection HDTV
I need to change a lamp
How do I get to the lamp to replace it. And what should I watch out for?
Can you show me any instructions?
Looking at the TV.....You have to unscrew the left side speaker panel. Then you have to unscrew the black panel next to the speaker - this exposes the lamp housing. Unscrew the two small screws that hold the housing in place and gently pull the lamp housing out. Now you need to see if the bulb is defective or not. I've gone through 4 bulbs in 4 years so get use to it. You can get the bulb/housing units online cheaper then what a TV service will cost. Good luck!!!
Posted on Dec 27, 2008
Wiring instructions for a simple plug for a lamp
BTW - Home Repair - Replacing a broken power plug ...
? 6:01
www.youtube.com/watch?v=_0dKFU0a4_A
Jul 11, 2011 - Uploaded by iamkeq in this episode i show how to replace a power plug that may have been cut off or ... How to repair a power cord that has been dog chewed.
Sep 30, 2015 | Cars & Trucks
How to replace lamp
Here's a link to show you how to change the lamp....tks :https://www.youtube.com/watch?v=_ONPuB5L-x4
Sep 07, 2014 | Televison & Video
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I have a Sony KDS-R50XBR1 I cannot remove the "old" XL5100 to replace it I follow the instructions to lift the ring, put my thumb on the groove and pull out Only it won't I cannot see...
XL5100 has lock lever that holds it intact inside tv, you need to put thumb on groove and press it to release the lock then pull out lamp, below image of lamp shows lock lever that moves upward when you press groove so lock gets release and lamp slides out very easily with little pull.
Please check new/ replacement lamp (if it is Sony original, it would be complete lamp including casing) for below mentioned lock function to have better idea how it works.
Hope these info will help you.
Thanks.
Jan 22, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
Light works but whole screen goes green. is this a
There is no design faults and no faulty lamps. Instead of lamp there is LED (light emitted diode), which is shining when the button is pressed. Click on my profile (escapement), then click on Tips and Tricks. There you will find link to RIP CURL watch manuals. If after following all instructions your watch still deliver same fault, visit your closest watch repair shop and ask to replace battery. Rate me, please..
Apr 01, 2010 | Ripcurl Watches
How do i change it
Here are the instructions on replacing the lamp.
http://service.us.panasonic.com/OPERMANPDF/TYLA2004.PDF
if you wish to only order the bulb itself and not the lamp assembly check this out.
http://www.youtube.com/watch?v=2YuOTYIqHhg
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 05, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Xl 2400 bulb replacement
Go to
www.dlplampguide.com
and select your set model and watch the video which is a YouTube video. Shows entire bulb replacement start to finish.
Jul 07, 2008 | Sony (XL-2400) Projector Lamp for...
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
JVC HD-52G786 52" Rear Projection HDTV Logo
74 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
