Question about Palm Zire 72 Special Edition Handheld
My Palm Zire 72 will no longer charge
When I plug my Palm into recharge it no longer charges. I thought it was the adapter so I bought a new one and get the same results. Nothing. What is the solution? I am in the UK right now and have 10 more days here and the battery is about out of juice. My sinc is at home in the US. I will lose all of my data on the PDA, correct?
    Novelist:
    Scholar:
  • 111 Answers
At first, before to want to be sure where is the problem is, you must do these sample tests: 1) Take out your battery and plug your power cord into your phone without battery. If : Power is on, there is definitely, your battery is bad and cannot hold a charge. If nothing happens, your internal battery may be dead and cannot hold charge so all info in your ROM of course has been washed away except the pre-load software by Palm. 2) At this step, you need to open your Palm if you know how to do to check for any bad connection between cable and use your volmeter to check the voltage output of your inner battery or can be called reserved battery whether it is have any power. If your reserved one has correct output voltage as in specs then check all connection around your power supply part to see any crack or defect. Please reviews the link below for detail: http://palmtops.about.com/od/pdarepair/Maintenance.htm I hope these info will give you some hints.
Posted on Apr 11, 2007
Palm zire 72 will not syn with pc running win 8.1
You find a fix to that problem, and the (Palm) world will beat a path to your door. HP, Palm's new owner, has attempted a fix for Win7, but Win8/8.1 may become the impossible hurdle.
Mar 30, 2014 | Palm Zire 71 Handheld
My PalmOne Zire 72S battery won't charge. How do I
I can't get the back off my 72s to replace the battery, any instructions would be appreciated. One source says there is a third screw in the wire mesh but I only found the 2 lower ones. Also, I can't find the Media Icon anywhere, therefore I can't use the camera or download pics. I even reloaded the software to no avail.
Nov 29, 2009 | Palm Zire 72 Special Edition Handheld
My PalmOne zire 72 screen is frozen on the real player screen and nothing was playing. Empty. I had just tried playing off a mem card. I thought it would read and play card? I'm a tech idiot!
Normal 0 The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Now for the link......
http://kb.palm.com/wps/portal/kb/na/zire/72/unlocked/supportservices/page_en.html
Nov 27, 2009 | Palm Zire 72 Special Edition Handheld
How do i fix a zire 21 palm it wont turn on, charge,work nothing
Hello.
From Palm support:
1. Press either the Date Book or Address Book button to see if
you can turn on your handheld that way.
2. Perform a soft reset: Use the tip of an unfolded paper clip
(or similar object without a sharp tip) to gently press the
reset button inside the hole on the back panel of your
handheld.
3. Make sure the power adapter is plugged securely into a
working electric outlet and is firmly connected to the
handheld. (If no outlet is available, your handheld can also
be charged through the USB cable, but this takes much
longer.)
Note: Your handheld does not have an indicator light to indicate that your handheld is being charged.
4. Charge for another three full hours.
5. If your handheld now turns on, check the charging-battery icon to ensure that your handheld is being charged. Example:
a. Connect the handheld to an outlet and turn it on.
b. Tap Home .
c. Look for the lightning bolt on the battery icon at the top of the screen.
d. If you do not see the lightning bolt, repeat steps 3 and 4.
Hope this helps.
Nov 03, 2009 | Palm Zire 21 P80730US Handheld
Pin in charge hole got loose then disappeared
Unfortunately this is a common problem, it can be repaired but unless you are an electronics technician I suggest you take it to the service provider if it's still under warranty. If not there will probably be a small fee. It may not be worth the cost to repair it so you may just want to replace the unit. Good luck
Oct 16, 2009 | Palm Zire 72 Handheld
No power and i cannot charge my palmone zire 72
Unfortunately Palm battery has a life cycle which is about 500 recharge after that will not charge well and will be end of its life. However you can replace the battery. Which can be obtained easily a 3.7V 700mA and above will work fine just make sure size will match
May 20, 2009 | Palm Zire 72 Special Edition Handheld
My PalmOne Zire 72 no longer re-charges. I think it might be the connection on the hand held unit itself. Does anybody here know where can I send it to have the repair done?
Its most likely caused by battery's life cycle has come to end. You may obtain a 3.7V OEM battery with same size of your original battery at least 700mA. you may replace if you wish to DIY or ask local repair tech assistance.
May 04, 2009 | Palm Zire 72 Handheld
Zire72's on the fritz!
Plug the ac wall adapter to charge the PDA and leave it there.
When the PDA exhausted the battery charge, it needs minimum 30 minutes to charge to the minimum level to have the PDA powering on.
Once it powers on, leave it charging the battery until is fully charged (3-4 hours).
Best regards,
Sep 02, 2008 | Palm Zire 72 Special Edition Handheld
AHHHH!!!!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Jul 12, 2007 | Palm Zire 72 Handheld
Palm Zire 72 Special Edition Handheld Logo
80 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
