Question about Mtd 22" Yard Machine Push Mower
Snow blower gets bogged down in snow.
I have single stage snow blower that is having trouble trowing snow. I replaced the belt last year, and the rubber impellors last night. I now throws light snow, but won't throw anything with any substance. It's like it doesn't have enougth RPM's
  • 1 more comment
  • kimcris Jan 18, 2009
    blower starts, paddlles turn and throws very light snow,not far,once i get to any depth of snow it stops turning and all i do is push the snow up into the front of the machie.
    mtd single-stage
  • royboy1999 Jan 22, 2009
    I have the same issue- Mine is barely over a year old and lost it's umph to throw snow. Are you sure it's not a belt or something that may be worn? The engine seems to run and start fine as it always has.
  • Anonymous Mar 20, 2014
    no balls when snow throwing must walk very slowly or it dies
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
It sounds like your engine is running lean, see if you can adjust the high throttle mixture on the carburetor (if possible at all). If there is no adjustment possible, it may be the carb is clogged and needs some service. Try cleaning it or find a new replacement carb for it.
Posted on Jan 10, 2009
WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE SNOW BLOWER VS A DUAL OR MULTI STAGE SNOW THROWER
Single stage has one rotating blade that collects and exhausts via upper shoot.
26373343-4yt0j151ox44pteg2g1nkeph-2-0.jpg Two stage has one blade for gathering into the center and a second that exhausts via shoot.
The two stage works best!!
26373343-4yt0j151ox44pteg2g1nkeph-2-5.jpg Hope this helps?
Nov 26, 2016 | Garden
Electric starter just spins and will not engage with flywheel
Does it try to engage and then pops off right away?
Is this a 2 cycle single stage snow blower?
Some single stage Toros have an issue with the Starter a $7 part cracks on the starter but is easily replaceable. Not sure what type of machine you have.
If it's a two stage snow blower then it is possible the shaft that the Bendix rides on is a bit rusted. Light sanding should clean it up
Mar 17, 2016 | Garden
I have an MTD single-stage snow blower that I replace the other the cable and the belt and under a load it's still not throwing snow
There should be 2 holes on the handle that engages the auger belt, use the top hole as it will increase the belt tension.
Check the condition of the rubber auger's rubber paddles as they are subject to wear and should be replaced if any signs of excessive
wear is present.
Jan 31, 2016 | Craftsman 21" 179cc* Single Stage...
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Snow thrower not throwing snow far enough
Your belt is probably slipping Is your snowblower a single stage or dual stage?
If it is single stage, there are normally multiple holes that you can put the engagement cable into on the lever. If so, move the cable to a hole that is further away, so the lever pulls the cable further. If it's already in the furthest hole, it's time for a new belt.
If you have a dual stage blower, the adjustment is usually made at the idler pulley, found under the belt cover.
Dec 03, 2011 | Garden
I broke a belt on the snowblower. How do i change the belt?
take the side panel off and loosen the belt tensioner, replace belt and re tension
Jan 06, 2011 | Garden
Craftsman single-stage snow thrower hard to push
You can adjust the guides on the side of the blower so that it rides on those. If they are set to low you will see the problem you have now. If they sit to low for a long period of time you can wear out the blade on the bottom.
Dec 22, 2009 | Toro Blowers Rake and Vac - Electric...
Mtd 22" Yard Machine Push Mower Logo
448 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
lnbn1975
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
