Question about Ricoh Aficio SP C410DN Laser Printer
Paper tray default issues
Color printer model # Aficio SP C410 DN it defaults to bypass try and won't recognize letter size paper in tray 1. was working fine yesterday until someone messed with it... don't know what they did.. When I try to print test page get error saying mis-matched paper size.
  • mgoodson Jan 27, 2009
    my printer has the same issues, however the language is not english
  • Anonymous Mar 12, 2009
    Our Ricoh SP C410DN has been switching tray priorities and Auto Tray selection for reasons we can't fathom. One minute it's pulling from Tray 1, the next it's insisting that paper be loaded in the Bypass Tray when there is paper in Tray 1, other times there's paper in Bypass (colored, labels etc) and it pulls from Tray 1. I've reprogrammed it up to 4 times a day, it works properly (Auto= Tray 1, Priority= Bypass) but it seems to revert back to it's own logic after a while.
  • 58 Answers
You need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 29, 2009
Ricoh SP C410 DN jam from bypass
If you can take off the bypass unit, two screws and a harness, you may be able to check the shaft, bushings and rollers. Sometimes removing jammed paper cause parts to get out of normal position. The grinding noise for example, gears not meshing together correctly. If it worked before the jam, then that is where I would look.
Apr 20, 2017 | Ricoh Aficio SP C410DN Laser Printer
Even though my printer settings are set to print and use the paper in tray 1 - the printer wants to pull from the bypass tray (which always pulls crooked). The printer used to work just fine then the alert...
Two things to check for a problem like this:
1) Driver Settings:
If your computer's drivers are telling the machine to pull from the bypass tray it'll ignore the machine settings. You're kind of on your own here figuring it out, if you can't though then try deleting the printer from the computer and re-installing it (will default settings)
2) Manual Feed sensor:
When you put paper into the bypass try you're activating a flag which tells a sensor there's paper there, if this flag is stuck forcing the sensor to constantly think you have paper there it would always to pull from there. Find the flag, move it back and forth, hit it with some air from a can of air.
May 31, 2011 | Ricoh AficioSP C222DN Laser Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
When trying to print, get error message to load paper into bypass tray. All printing preferences have the input tray as tray 1?
if all the other trays are empty
or the bypass is set as default
or the bypass has the correct tray size and no one else has it
then the bypass will be default...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 09, 2009 | Sharp AR-BC260 Color Copier
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Ricoh Aficio C410 bypass tray not picking up and reporting jam
This is happening to me also. The rollers sound like they're turning, but the paper doesn't advance. I then go into th emachine and spin the roller cam a bit and it seems to clear the problem. Any idea what's happening?
Jun 09, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh/Aficio SP C410DN Tray priority switches on its own
It is pulling paper from the tray specified within the application you are printing from or the driver. For example, from Microsoft word, you would have to go into page setup and select the tray you would like it to pull from. You will also want to check which tray it is pulling from in the driver, however the application generally overrides the driver settings. Both of which override anything you program at the machine.
Mar 12, 2009 | Ricoh Aficio SP C410DN Laser Printer
Printing from the wrong tray on the Ricoh C410 DN
these settings need to be done with the RPCS printer driver, go to properties and then custom settings from there you can tell the printer where to print from.
Dec 30, 2008 | Ricoh Aficio SP C410DN Laser Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Ricoh Aficio SP C410DN Laser Printer Logo
856 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
