Question about Hamilton Beach Water Cooler with Storage Cabinet
I cannot dispense water from the cold water/fan runs all the time
Seems I can unplug unit for 24 hours and it works for a couple hours correctly then seems to "freeze up" I noticed that the dual cooling chip was missing for a couple months and have recently replaced but still not working correctly.
  • Anonymous Dec 31, 2008
    Thanks for the info...I'm talking about a hamilton beach water cooler, not a refriderator. Is there some way I can turn down the temp on my water cooler?
    Thanks
  • 700 Answers
First of what temperature are you running is the refrigerator and also what is the ambient temp? whats happeneing is that the water resevour is freezing in the back of the refrigerator . So if the temperature is say 34 iit can actually be a lot colder in the regfriigerator than that due to temperature averaging. Thanks fpor using Fixya and Merry Christmas
Posted on Dec 23, 2008
Ice tray not filling
The unit will not allow water to enter the frig til the temp is cold enough to make ice.
Nov 06, 2012 | Bosch Refrigerators
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator and freezer were working properly before an extended vacation. Cleaned both refrigerator and freezer, unplugged, and left doors open. Upon return plugged in and have waited 72 hours. ...
Let's think this through a bit....
You say it is cooling but it seems too quiet.... is the compressor runing but the condenser fan is not??? that would make it cool but not cold and also make it more quiet...
If both compressor and condenser fan are running... is the evaporator fan... the one inside the freezer running? That also could cause the same problems...
Is the compressor running all of the time??? or is it cycling? if it is cycling then it could be a t-stat or sensor problem....if it is not starting properly it may be a capacitor/relay problem...
These are alll things that you can easily check yourself....
If they all checkout... then the unit may have a small refrigerant leak and just will not cool enough now to catchup from a earm condition....
To check that out you would need a tech. to attach gauges to the system and check the charge...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
Amana Side by Side Refrigerator
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Apr 24, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The ice maker will not quit dispensing ice and it no longer cools
For now unplug the pin plug at lower freezer door hinge and disable the dispenser control board until we see if the keyboard or the dispenser board is at fault. Sea Breeze
Feb 22, 2010 | GE GSL25JFPBS Side by Side Refrigerator
This fridge won't dispense water. It did this morning, nothing done all day that could affect fridge or water supply. I'm an engineer and I know a little about tracing problems. I checked the line in at...
my guess is things work till they don;t . and if your problem is simple we can solve it as. 2 mind's are better than one . if the frig is running longer to keep cold . it could be dust on the cond coil . or the cond fan running slower than it did yester day . . so clean condener and ck fan. and set the tempt in fresh food to a warmer seting . for 24 hr. . also the water valve may have failed as it 's a dual valve one side for ice and other water .. . on filter models 3 sol are on valve .. mm hope this helped. mm
Jan 06, 2010 | GE GSH22JFT Energy Star 22.0 Cu. Ft....
Cans are not cold enough
Try just unplugging the unit and leave the door open for 24 hours. Your problem is sometimes caused by a heavy frost and ice build up on the evaporator plate behind the dispensing unit. After 24 hours, plug the unit back in, reset the thermostat to the 11:00 position and close the door. I hope this helps.
Apr 04, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox is freezing and making a humming noice.
The temperature in the SkyBox is controlled by the thermostat located within the beverage compartment. If set too high, product can feeze. In addition ice will build up behind the dispenser assembly. The ice buildup can eventually make contact with the circulating fan blade and cause a constant noise.
You should hear the compressor stop running as you turn down the cold control, but prior to reaching the "off" position. Select a lower setting for the cold control, and unplug the unit for 24 hours with door open to thaw out the ice build up. Reconnect power to resume normal operation.
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Nov 07, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler with Storage Cabinet Logo
372 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
fixits
Level 1 Expert
Dan Webster
Dan Webster
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
