Question about Konica Minolta magicolor 2400 Laser Printer
Paper jam at the Transfer Roll
The error message keeps coming up at "Paper jam at the transfer roll." I do not see any jam at all and am not sure what to try next. The machine has been cleaned throughly. Djohnson
  • 3 Answers
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something.  I have done it a number of times - usually after a paper jam.
Posted on Oct 30, 2007
I have a Lexmark T652N that says it has a jam, but I cannot find it. It comes up with error 200.13 Paper Jam - check cartridge
200.13 - Input sensor jam.
The flag sensor that is located before the transfer roll and next to the end of the alignment rollers. Make sure the flag is still there. It can be easily broken. If it is there, make sure it moves forward and springs back into place. If it is missing or doesn't move properly, it needs replaced.
Input Sensor - 40X8673
Jan 27, 2015 | Lexmark T652N Mono Laser Printer
How do i adjust heat settings in xerox 6110
If you tried to print on a transparency sheet for ink jet printers, in your laser printer, you could have damaged the heating rolls. The plastic could be molten on the roll and you won't be able to remove it without damaging the roll. As long as there is just a spec of plastic on the roll you will have paper jams. There should be transparency sheets for laser printers to, but always make sure you have those before using in a laser printer.
Jun 21, 2014 | Xerox Phaser 6110 Laser Printer
What does this error message mean: "917.00 service transfer roll"
The transfer roller is missing, not touching the drum, poor contact to the transfer high voltage or transfer high voltage shorted.
The trasfer roller is below the drum. Its bearings are on springs to press the paper against the drum. The drum rotates it by gears at one end. One of the bearings have electrical contact with the spring and the spring is connected to the DC controller. The transfer roller receives high voltage that attracts the toner from the drum. It's current is measured and when it's not within specifications the error occures.
Aug 05, 2010 | Dell 5210n Laser Printer
Error message 917.00 service transfer roller. I replacedn the service roller but still the error message comes up.This is from the IBM Infoprint 1552.
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
Feb 11, 2010 | Office Equipment & Supplies
Error 917 - Service Transfer Roller. I have replaced the transfer roller on my lexmark e350d, but I am still getting the error. Not sure where to go at this point.
Hello my friend.First maake sure the printer is powered off before making any checks on the transfer roll or associated parts for personal safety and to prevent damage to the printer.
1.Check the transfer roll for any signs
of toner buildup, surface damage to the roll, oil or other contaminants on the surface of the roll. Replace the transfer roll as necessary.
2.Check the left transfer roll arm
assembly to make sure it is fastened and locked in the down position. If the arm is not locked down, check to ensure the arm is not broken and will lock into the EP frame correctly.
Check the left transfer arm assembly spring for proper operation.
3.Check the right transfer arm assembly to make sure it is fastened
and locked in the down position. If the arm is not locked down, check to make sure the arm is not broken and will lock into the EP frame correctly.
Check the right transfer arm assembly spring for proper operation. For any background problems, check to ensure the
contact to the HVPS board is correct and that there is approximately 0ohms resistance between the transfer roll shaft and the HVPS contact.
4 . The voltage changes from +24 V dc with the printer idle to 0 V dc when the printer runs the print test. If the voltage is incorrect, check the continuity of line J10-3 in the front
cable harness to the HVPS. If there is no continuity, replace the cable harness. If there is continuity, replace the HVPS. If the problem continues, replace the engine board.
Feb 08, 2010 | Office Equipment & Supplies
SERVICE CALL 14 XFER ROLLER Have installed new transfer belt. Still had error message. Came here and read tips. Cleaned the sensor both in the printer and on the transfer belt; reinstalled. Still...
the transfer roller is a foam roller that transfers the toner onto the paper. It will be visible with toner removed, a little wider than a piece of paper, and about the thickness of a roll of quarters. I don't know how to physically remove it on your model, but transfer roller issues in general can be remedied by removing the transfer roller and wrapping it in packing tape until the tape comes off clean.
While you're in there, vacuum everything out for good measure; but never, ever use canned air on a laser printer.
Jan 03, 2010 | Minolta magicolor 2200 DeskLaser Printer
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Will not fax or copy - Given error light
The thermal roll is basically a roll of 'carbon' like paper that is used to transfer the image to your paper (terrible technolgy, and a massive waste of money for the end user....but that's another story)...it likely needs replacing -it's only good for 300-400 pages.
Feb 24, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Printer problem
Your transfer roller needs replacing.
Feb 22, 2008 | Lexmark T630 Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
379 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
