Question about Dishwashers
Kitchenaid Superba (model # KUDS01FLBL6). The light by the control lock/sanitized/clean on the control panel keeps blinking. I called Kitchenaid and they recommended turning off the circuit breaker. I did this for 5 minutes and the light is still blinking. Washer won't run. Help!! Family is in for Christmas and I can't wash everything by hand...I'll never leave the kitchen!
micromaster
  • 3614 Answers
SOURCE: Kitchenaid superba
Do the dishwasher still operate or not?
Posted on Feb 23, 2008
SOURCE: Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Mar 24, 2008
mohammed387
  • 1952 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
Posted on Sep 21, 2008
SOURCE: My KitchenAid Superba won't run, no lights, nothing
turn off the power at the breaker and let it stay off for at least one hour
Posted on Dec 18, 2008
heatman101
  • 43501 Answers
SOURCE: Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Posted on Oct 03, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
How do I turn off the childproof lock on my KitchenAid Superbua dishwasher?
This depends on the exact model of the KitchenAid Superba dishwasher. There is a button on the control panel that will indicate the Control Panel Lock. Usually this is labeled Control Lock (Hold 3 sec) or 4 Hour Delay (Control Lck 3 Sec). The phrase in parentheses is below the key in a smaller font.
Press and hold the button to toggle the lock on and off. Sometimes you have to hold it for more than the listed 3 seconds.
I hope this helps.
(my reference was the manual for the KitchenAid KUDE40FXSP . Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Just enter the model number and the type of person researching the documentation (consumer).)
Jul 14, 2011 | KitchenAid Dishwashers
Kitchen aid model superba selectra oven door will not unlock after self clean control panel shows f3
One fellow with a similar model explained what he did to a similar model:
http://www.ehow.com/how_5499974_unlock-kitchenaid-superba-oven-locked.html
Another person with a different model mentioned hitting cancel 3 times. Another method was to press function, (5), then (2).
Aug 26, 2010 | Computers & Internet
"SANITIZED CLEAN" GREEN LIGHT IS BLINKING
This is an indication that the water did not heat properly, I have put some instructions together that will show you how to reset the control and what might have caused it. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
Over temperature reset button keeps ringing and blinking
I called the KitchenAid customer support number. Found out that control goes off when the temperature of the fridge is above 48 degrees (i.e., over a few days, the food would be spoiling). This is not the case for ours, since everything seems to be working fine. They said there is probably something malfunctioning with that button/control, and there is no manual turn-off mechanism. We have to call someone to come and fix it.
Jan 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid dishwasher woudl not work MOD KUDPO1FLWH6
is it on steady??? or blinking??? if on steady try pressing nad holding the button with the "lock" symbol on/or above it, thinknits the heat button, for 3 secs it will "unlock" the controls, if blinkin then its a diff issue, may be a bad door switch not recognizing hte door being closed therefore wont start,
Dec 02, 2008 | Dishwashers
Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Feb 12, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
556 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
