Question about Hunter Low Profile III 20807 Ceiling Fan
Broken pull cord for the 3 speed fan (Hunter kiw profile)
The entire cord is out. I am unsure how to replace the switch as I do not have any manuals for the fan so I am even unsure of the model number.
    Problem Solver:
  • 8 Answers
Turn off circuit breaker to fan. Remove bottom cover plate. Remove thumb nut holding switch in place. Examine switch. Places where wires push in should be numbered. Write down number and coresponding wire color. Remove wires from switch. Take switch with you. Walmart carries some switches but if you can't find it there go to a Locke supply store. Know how many speeds the fan iswhen you go looking. Reassamble in reverse order.
Posted on Dec 26, 2008
How do I replace pull chain on old hunter fan. No replacement available Home Depot gave generic switch. I don't know what wire color goes in switch L 1 2 3 Wire colors are red black blue
If that's a two speed hunter, you have the wrong switch. You need to get a two-speed switch. This switch comes with the wires attached. Do you have the fan model?
Mar 15, 2015 | Hunter Dryers
I have a Hampton Bay 3 speed fan. Replaced the switch that was broken but cannot get the speeds to switch correctly. fan will not turn off. and the speeds does not change. I have switched the wires around...
Most likely you have the wrong switch. You ncan't go to Home depot or Lowes and buy a generic switch off the rack and expect it to work (no matter what they tell you)Call Hunter & order switch #6378401000. 1-888-830-1326
Feb 13, 2013 | Hunter Low Profile III 20807 Ceiling Fan
Hunter waldon 21778 pull cord replacement The only place I could really find parts was at this Hunterfan site. There is a phone number on there. If the pull chain is pulled from the switch you may need the switch assembly but if is just the chain you can find those at any hardware store.
Sep 03, 2012 | Hunter Low Profile III 20807 Ceiling Fan
3-speed fan switch broke on Hunter model 28072, cat. 300 fan. Found replacement switch at Lowes, but wiring colors are completely different from manual. What color wires go into L, 1, 2, 3 positions...
My Hunter fan uses a Zing-Ear ZE-268S6 switch. This is NOT a standard switch! It connects L to 2 AND 3 for medium speed. It is best to order the exact switch if possible. Hunter wants to sell you the entire bottom assembly (probably expensive). I found the exact switch online at:
for $6.80 plus $4.95 shipping. I bought an extra which didn't increase the shipping - worked great. Hunter ZE-268S6 ceiling fan connection colors: L=black; 3=green; 1=grey; 2=brown. If you need a different switch on their page, just click the Edit menu, then Find, type your part number in the box, and click Next.
Nov 30, 2010 | Hunter Ceiling Fan Control Switch
Receiver 85112-04 need a replacement for hunter fan remote receiver which is housed in the based of the fan in ceiling.
I realize that this is an old post. However, the best solution is to replace the receiver with 3 or 4 speed wire harness, which includes the capacitor, fan speed switch, forward/reverse switch and female plug for $15 as of today's writing. While you may be able to find a 85112-04 replacement receiver, I found them to be an expensive solution at $80. In addition, there is no telling how long the replacement receiver would last. To purchase a 4 speed wire harness for this Hunter fan, they can be ordered from
Casablanca. Casablanca you say? Yes! Casablanca is a subsidiary of Hunter Fans. This 4 speed wire harness, part number K016501H01, is standard in many Hunter and Casablanca fans. Hopefully this will help someone looking for a low-cost solution to replacing the fan. Link below:
Apr 11, 2010 | Hunter Ceiling Fan Remote Receiver...
Just replaced broken pull 3-speed switch. Fan now only runs on two speeds, need wiring diagram please
I ran into this when replacing the 3 spd switch. The replacement switch has a pair of connections at each position; you would assume the two connections are electrically tied together, they are not. The switch assembly actually has two seperate 4-position rotary switches. If your "L" wire is on the 'inner' connection, then your motor speed wires will have to be as well.
Jul 27, 2009 | Hunter Dryers
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Hunter ceiling speed.
A fan that old has a muilti speed capacitor. It could be that or the swicth. First thing to do is test the swicth with a voltage tester to see if power is switched to different posts if it does switch it is prob. the cap. Good luck trying to find one.
Apr 06, 2008 | Hunter Low Profile III 20807 Ceiling Fan
Hunter Low Profile III 20807 Ceiling Fan Logo
421 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
