Question about Kenwood KM300 Chef Stand Mixer
Lift handle plastic cover broken
I have a KM210 mixer which I love. My darling son-in-law used it and broke the little gray handle which you use to lift the head up. Is there any place that sells small replacement parts?
  • Alex Pomar
    Alex Pomar May 11, 2010
    hello. you can get theses parts in
    4kenwood.co.uk
    regards
    Alex
Piece of lid broke off
Sand the area on bottom of piece along with areas surrounding the broken piece. Get another small piece of plastic that is large enough to cover the broken piece and adjacent areas and apply the glue to that using a good epoxy for adhesion. Let it set up and it will hold - trust me.
Sep 27, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
KM210 HEAD LIFT KNOB NEEDED PLS
contact the manufacturer is only option I believe you have
Jul 22, 2015 | Food Mixers
RESET A HOBART 140 QT MIXER
The V-1401 has a power bowl lift that is belt driven by the same motor that is used to mix. Remove top cover to check the belt. If belt is good and not slipping, is the operator handle working on /in the bowl lift gear box? If not, could be broken shear pin on handle or worn out parts in gear box. Next thing to check is the output shaft of the bowl lift gear box. If it is turning when the operator handle is engaged and the bowl lift jack shaft is not turning there is a broken shear pin between the output shaft and jack shaft. If everything is good to this point the bowl lift yoke has a large brass nut on back side of it that the jack shaft goes through. If the nut is worn the bowl lift yoke will slip, fall and/or jam. to unstick and lower the bowl , one can turn the jack shaft by hand. WARNNING : if the nut is worn enough the yoke can drop suddenly and it is very heavy.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
What serial number mixers have a plastic gear cover
All of the new style that are made after 2002 0r 3 that are bowl lift models and up untill 2008, They no longer make the plastic as it could not handle the work load all are made now with a cast aluminium cover. Hope that helps
Oct 10, 2014 | KitchenAid Pro 600 Stand Mixer KP26M1X-...
Km210 kenwood
Try a company called e spares on the internet they do parts for a lot of items
Jan 30, 2014 | Food Mixers
Looking for Kenwood bowl 28589 for KM210
Hi, are you after a used or brand new?
Nov 19, 2013 | Food Mixers
I have had my stand mixer for approximately 12 years with no problems until today. The mixer attachment I used will not come off. The gear/top continues to turn under my pressure as I try to lift up on the...
Tap it with a spatula handle, something with a little weight to it but soft like plastic or wood. Give it some pressure in the direction you want it to go and then hit it in that direction too.
Run a little sandpaper inside the mounting hole in the attachment when you get it off, it's probably got a little corrosion on it. Sugar can make them stick too, a little hot water brushed on will help if it's got sugar in it.
lp
Jan 11, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The lever to adjust bowl height will not move.
most of the times it is because of build up between lift handle and pedestle case use wd-40 and even some heat from a torch to help loosen up stuck handle. also wd-40 the ways on the mixer ped. where the bowl yoke is
Dec 15, 2009 | Hobart A200 Stand Mixer
Manual for km210 please
kitchen.manualsonline.com/ex/thread/view/.../2371332
www.manualsnguides.com/search.php?cmarque...KM210 use this link
Sep 11, 2009 | Kenwood KM300 Chef Stand Mixer
Beater keeps falling out. The plastic thing at the top of the beater inside the mixer needs to be replaced. Where can I get the part?
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG -- 0d345a3.jpg-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --8982711.jpg -- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --d67ddea.jpg -- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body. 3297c2c.jpg----
Oct 16, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Kenwood KM300 Chef Stand Mixer Logo
148 people viewed this question
Top Kenwood Food Mixers Experts
jason
Oscar Netto
Oscar Netto
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
