Question about Tanaka Commercial Grade "Inspire" Design Straight Shaft SplitBoom Grass Trimmer Brush Cutter 23cc 12 HP 2Stroke TBC240SFS
Tanaka tht 2100-very difficult to start. Pull cord is is either too loose when pulled or it is jumpy, meeting with a bit of resistance?
The pull cord recently snapped and I replaced with a new cord. when i pull the cord to start it either slips and makes that cllicking noise like it is not engaging or when it does engage it pulls with resistance. there is spark in the plug, but it feels like bearings have ceased on it or something
  • Michael White Sep 03, 2012
    Sorry my question may be misleading as I said "it is difficult to start", in fact it doesn't start.
    New Friend:
    Problem Solver:
  • 6 Answers
I think it sounds like the motor is going i had a chainsaw and it did the same thing after a while the motor went and the chainsaw was no good anymore so you mite want to take it to a dealer that deals with your grass trimmer
Posted on Sep 03, 2012
5 Suggested Answers
SOURCE:
jyackle5
  • 8197 Answers
SOURCE: parts list tanaka hedge trimmer
You can get the service manual on link below.
http://tanakapowerequipment.com/pdf/serv/Tanaka_HT_Service_Manual.pdf
On this link below is the parts list.
http://www.tanaka-usa.com/pdf/dpl/hedge_trimmers/THT-2100dpl.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jun 27, 2010
  • 3600 Answers
SOURCE: my tanaka chain saw wont idle and when i pull the
clean spark plug and gap, remove air filter and clean, look at the spark plug and tell us what color it is, You may need to adjust the fuel mis to get it to run right or you may need a gas filter. Post here with more information.
Posted on Aug 28, 2009
  • 21887 Answers
SOURCE: the pull cord has lost it's ratchet where do we
call their 800 number they can tell u where to find local dealer or can order part over phone
Posted on Oct 05, 2009
eugbug
  • 479 Answers
SOURCE: where in ireland can i get parts for a tanaka THT
Try http://www.gardenmachinery.ie/
They have a list of dealers who may supply parts.
Posted on Dec 10, 2010
I have a Tanaka THT 210 Hedge Trimmer. What is the fuel mix ratio please.
50:1
The hedge trimmer is equipped with a two-stroke engine. Always run the engine on fuel, which is mixed with oil. Provide good ventilation, when fueling or handling fuel. Use Tanaka two-cycle oil or a quality two-cycle oil at mixing ratio of 50:1 (Gasoline (A) : Oil (B)).
Page 6 of Tanaka Trimmer THT-210, THT-210s, THT-2000, THT-2100 ...
lawnandgarden.manualsonline.com/.../tanaka/hedge_trimmer_model_tht210210s20002...
tanaka tht 210 manual Google Search
Sep 23, 2018 | Tanaka Garden
What is fuel mix ratio for Tanaka tht 210
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
I have just purchase a Sears 22 Lawm mower, with a Briggs and Stratton 158cc engine. I prime the motor it act like it wants to start but then dies. I pull it and try to strat it several more times and it...
The procedure for starting an engine is as follows:
  • Check that you have the throttle in the start position and/or on high revs with choke on
  • Prime the engine by pushing the button about 5 times
  • Pull out the cord until you meet resistance. Then let the cord go fully back into the engine and then pull the cord out sharply. Repeat this until the engine starts but not more than a few times.
  • If the engine doesn't start, try pressing the primer button another few times then try to pull start the engine
  • If the engine doesn't start after a few pulls it may have flooded so leave it for a few minutes before pulling the starter rope
Apr 30, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Where in ireland can i get parts for a tanaka THT 2100 hedge trimmer
Oct 20, 2010 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Parts list tanaka hedge trimmer
Jun 27, 2010 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Pull cord difficult to pull..removed from saw it works fine..with spark plug installed hard to pull ..with plug removed (of course there is no compression) ,the pull cord pulls easily..saw worked greatall...
Make sure someone hasn't run this saw without the oil in the fuel mixture. It is possible it is dry and some galling is happening. Or - if this saw is equipped with a compression bleeder (for easier starting), this could be not functioning and you're pulling through the normal compression (which can be a bit feisty!). Check for misalignment of some type having to do with the pull starter - check that the cord spool isn't rubbing on the housing when you pull. Good luck.
Nov 30, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Stihl KM 55 won't start
1. 1st change the spark plug to NGK BPMR 7A.
2. Set the kill switch to on position (I)
3. lock the throttle interlock on
4. Do not prime the fuel bulb...this may cause flooding.
5. set the choke to full choke.
6. pull the cord gently until the piston resists then pull hard
7. repeat pull a second time
8. open choke all the way
9. pull cord again hard.
engine should start within 2-3 pulls, release throttle and feather the throttle until stable
Apr 04, 2009 | Hand Tools
Tanaka Commercial Grade "Inspire" Design Straight Shaft SplitBoom Grass Trimmer  Brush Cutter 23cc 12 HP 2Stroke TBC240SFS Logo
222 people viewed this question
Top Tanaka Garden Experts
john h
Nick Olsen
matt
matt
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
