Question about 831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS
Remote car starter problem.....?
My remote starter will start the engine just fine BUT it shuts the engine down after a minute or 2. If I start it with the key it starts and runs with no problems. Any ideas??
  • gd_spalding Jan 06, 2009
    My remote starts the truck, but with key in and on when I step on brake to put in gear it shuts off?
  • 34 Answers
Need to know what car and model of unit you have . it is a sec. or ignition wire problem
Posted on Jan 09, 2009
Remote starter comes only briefly and shuts off
Factory Remote Starter Quits After 5 Seconds - Diesel Place ...
www.dieselplace.com/.../340832-factory-remote-starter-quits-after-5-sec...
Nov 23, 2009 - 11 posts - ‎8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ... check engine light on wont shift
Oct 28, 2011
remote start
Oct 14, 2008
More results from www.dieselplace.com
Factory Remote Start Problem - 1999-2006 & 2007-2013 Chevrolet ...
www.gm-trucks.com/forums/topic/114985-factory-remote-start-problem/
Jun 12, 2010 - 10 posts - ‎8 authors
Factory Remote Start Problem - posted in 1999-2006 & 2007-2013 ... Sounds like you may have an intermittant code coming in and the dealer should be able to pull it out.2008 Sierra SLT ECSB Z71, Corsa Touring, and GMPP CAI .... the remote start button again the truck WILL shut off and the only way to ... Burning smell, white smoke - 2014 / 2015 / 2016 ...
Jan 11, 2014
2008 Silverado Electrical Issue
Aug 19, 2012
Making Factory Remote Start Run Longer
Dec 21, 2010
2000 Sierra, Starts Then Dies - Code 1631
Dec 4, 2008
More results from www.gm-trucks.com
Jan 05, 2016 | 2008 Chevrolet Silverado 2500HD
I have an autopage remote starter that worked just fine until I replaced the battery in my vehicle. The remote still works, everything still works except it runs for about a minute, shuts off, restarts,...
sounds like security system is keeping it from running. try this. disconnect the battery again. lock the drivers door with the key. reconnect battery, unlock drivers door with the key and try and start the car with the key. does this work?? ok now shut car off and lock it and try remote starter. hope it works it just might
Dec 03, 2017 | Cars & Trucks
When I put the key in the ignition it doesn't try to start everything else comes on then shuts off. I drove it yesterday but now it won't work
The remote starter module is not getting an electrical signal when you turn the key to the on position after remote stating the vehicle. When you depress the brake without turning the key on the vehicle shuts down. The remote module thinks the key is off even when you turn it on. There is a loose connection or the remote start device is defective.
Jun 04, 2014 | 2005 Chrysler 300
Remote car starter starts vehicle but vehicle shuts off right after
you have "lived" with for 14 years now so why are u trying to fix it now?????????
anyway find where remote starter's relays are under dash test the relays... one of them is broken or not wired right.
May 15, 2017 | GPS
Last Year I installed an AVITAL5103 Remote start & Security on My 2002 DODGE RAM 1500 Q.Cab.Everything was working fine,util I instal a new car battery.When I attempt to remote stert ,the starter cra
There are two types of starters for Dodge, if you installed new battery, check to see if the remote start is to ignition module or starter solenoid, then make sure the circuit has not been closed-they go in series circuit!
Nov 29, 2011 | 5103L Security/Remote Start System
I have a Viper 5301 LE 2 way remote starter system installed in a manual transmission. When I set my starter everything seems to be functioning normally. Once I get out of the car and hit the lock button...
It sounds like the turbo timer mode is active. In this procedure, the MTS remote starter is active, it's just that once set (after locking the vehicle) the vehicle will run the preset time(1,3,5 or 10 minutes) before shutting down. The MTS remote starter feature should still operate with the turbo timer mode.
Feb 08, 2011 | 5301 LE 2 Way Car Remote Starter System
Nissan Altima 2000 Manual. Recently had remote starter installed and was working fine for a few days. This morning I remote started the vehicle and when I came out car was off. Try starting the car up...
the remote starter is not going to damage the starter, but if wired wrong it could damage the wiring or fuses, or run the battery down from a short.
Jun 11, 2017 | Nissan Altima Cars & Trucks
I have installed a bull dog remote starter on my 2001 grand am. everything starts fine but car wont shut off with the key.
This would only happen if you did not install the brake cut off switch. You will be able to shut the car off with the key after 15 minutes or with the remote.
Oct 31, 2009 | Remote Starter with Keyless Entry
Remote starter on a 2004 Accord with V6 engine
remote starter is designed to shut down the vehicle if there is no key to drive with. This is a security feature so that unauthorzed drivers cannot steal it. to answer second question the purpose of remote starters is to allow you to heat up the vehicle so it is an ice cube when you are ready to drive. Not sure what remote I cannot answer the horn question. Need more on what remote starter you have model number and make
Apr 20, 2009 | 2004 Honda Accord
Remote starter malfunction
new battery, the old battery terminals were terrible corroded
Dec 07, 2008 | Remote Starter with Keyless Entry
831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS Logo
1,308 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
Philip Armitage
john h
D. E. Hev
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
