Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
Analogue LG Flatron
Every time I try to turn on the monitor it goes into a "safe mode". I originally thought it was my computer so I reimaged the Hard Drive and it worked well for one day. Now when the pc is turned off and I turn the monitor on it will only go to "safe mode". This is very frustrating, what can I do to correct this problem.
    Problem Solver:
  • 17 Answers
The monitor is working ok if it goes to safe mode with no input.which do you turn on first?(to work out which could be faulty)It is most likely that the monitor data cable is the fault(at either end) or the PC m'bd disp skt,try pluging an add on disp'card in to the PC. Regards Chook.
Posted on Apr 27, 2007
Flatron W2353 monitor wont turn on
LG W2353 dvi power saving mode
how to fix ?
Dec 22, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
Monitor sleep problem
This type of problem is usually caused by a failure of the filter capacitors on the power supply board. The LG L204ws uses the AIP-0156 power supply which is the same board used in many of the LG monitors that were sold around the same time. Here is a link to a repair guide for the LG L226wtq model that used that board. The repair guide as pictures and videos showing how to open the unit and check the filter caps. There are parts lists showing what needs to be replaced too.
http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/
I hope this helps,
BuddyMc
Dec 01, 2012 | Computers & Internet
My 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Dec 14, 2010 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Brand New LG Computer Monitor Flickers/Goes Into Power Save Mode
well right click on your desktop and goto properties and then goto screen saver and then goto power and then on the monitor setting goto never.
Sep 20, 2009 | LG Flatron L2320A 23" LCD Monitor
Flatron L1953S Goes to power saving mode while playing..
I had the same problem with my LG Flatron (not the same model as your one). I fixed it by connecting both the digital and analogue cables from the pc. Presumably, the problem occurs because the monitor is not receiving a digital signal.
Mar 18, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Flatron W2252TQ goes into 'power saving mode'
I had a similar problem with an LG monitor that I resolved by connecting the analogue cable as well as the digital cable from the pc. This problem must be caused by the monitor not receiving a digital signal.
Mar 08, 2009 | LG W2252TQ Monitor
How to temporarely disable analogue power saving mode
Go the desktop, right click with mouse and select properties (if it XP) then it will open Display properties --> there you need to go to Screen saver and then to power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
Nov 13, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
97 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
