Dell 32inch Tv Model W3202MC remote control code?
I have recently upgraded to a Virgin media V+ box which is connected to my TV via a HDMI cable - my remote does not function fully at present. I need to obtain the remote control code in order to correct this position.Can you help?
Many thanks.
John Ranson
  • 6 Answers
SOURCE: I have an Optimum Online
Is it iO tv? If so, here.
Posted on Jan 23, 2009
SOURCE: virgin media tv remote control
what you have to do is ring virgin and ask then to send the code.
this code is done stight to your set top box
Posted on Feb 08, 2008
  • 25 Answers
SOURCE: Need remote code for Bresnan Cable 5-1 remote for Sharp 32" LCD
Apparently I didn't read the directions for code search closely enough (as it does work for my tv). So I will post them here, just to be sure people don't make the same mistake I did.
With the Device on;
1) Press "TV" on the remote control
2) Press and Hold the "Setup" button until the light blinks twice
3) Enter "9" "9" "1" to enter code search mode on the remote
4) Press the the "CH+" slowly until your TV turns off (if you accidently go to far your can press "CH-" to go back a code or two)
5) Press the "Setup" key to lock in the code, the light should blink twice if done correctly
Your device is now programmed, enjoy!
Posted on Dec 31, 2008
SOURCE: tuning samsung tv into virgin media cable box
Make sure you have a Vigin Media branded remote control, then try your codes.
0079 Worked for mine.
Posted on Feb 28, 2009
SOURCE: remote control code/daenyx tv/dvd combo
Daenyx is a company from India......if you look at their website, there is 5 spelling mistakes in the introduction... They cannot even take the time to proof read.....I would stay away from their products.....seems like they do not pay attention to detail.
Posted on Mar 30, 2009
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Nov 07, 2017 | Internet Computers & Internet
How do I connect a virgin v box to an old lg model?
The hdmi cable would not be compatible with your old style TV, if the Virgin box has a scart socket then that is your best option!
Nov 07, 2014 | LG Televison & Video
We have aproline tv - LVD1985WD and need to set our Virgin Media Box up to it but dont know how to
they should be three ways to connect to your tv, firstly using the HDMI connection (if your using the HDMI for something else buy a 4way HDMI box), the second is to connect using the SCART lead connector, and the third is to use a VCBS connector (AUX leads, one yellow (video), and one white (left audio) and the other red (right audio). other than these they shouldn't be any other way to connect to your tv. Unless you use a S-video lead. all these ports sould be available on the back of the tv set. to use your Virgin remote with your tv they should be instructions on how to use the program codes either in the paper work that came with your tv or simply search online for the codes to your remote.
Sep 18, 2011 | Pro Line 2089VYD TV
I need a code list for my remote set top is for a panasonic viera 32inch lcd flat panel television.
Hello zaninc and welcome to FixYa. I'm not sure if you are referring to the codes for your cable box or your actual television so I have provided codes for both.
Panasonic Television Codes
0051, 0055, 0250
Panasonic Cable Box Codes
0000, 0107, 0021
Note if your remote control only accepts three digit codes you will have to take the first zero off of the codes that I have provided in order for them to work.
If these codes do not work for you please inform me of what make and model of set top box you own using the comments box and I will get right back to you. Thank you for using FixYa and good luck zadinc.
Apr 26, 2011 | Sagem Televison & Video
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
Hi, I have a 32LG3000 HD tv with software version 3.47.1. I just bought a Humax FoxT2 HD free view box but when connected via hdmi to the LG tv a message briefly comes up on the tv saying invalid format...
I , would try using another ( alternative connection) from your humax , say the scart cable just to see if it , the humax is ok. then if tv has more than 1 hdmi skt try it too, if still not working retry upgrade firmware route
Nov 11, 2010 | LG 32LC7D Television
No HDMI on the source list, i have a Virgin Media V+ Box with a HD cable pugged in and when i look at the source list the HDMI Port is not Highlighted, why is this? Please help
One of a few things are happening. If you are connected to the TV via the HDMI port and it doesn't become highlighted then either the main board on the TV is at fault, the HDMI output on the media box is not working (try on another TV if possible) or the HDMI cable itself is bad.
Nov 03, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Problem with tv sender
Hi,i learned on another forum that if you connect an hdmi cable apparently it disables the functions of the scart sockets,especially where the remote control is concerned.This is something to do with virgin media's setup and not any equipment fault.If you want to go back to two room viewing try unplugging the hdmi lead.
Jun 22, 2009 | Philips Televison & Video
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
