Question about GE Spacemaker JVM1640SJ Microwave Oven
Buzz, plastic smell and no heat
My above-range with vent GE microwave (7 years old)stopped working today. The lights come on, the turntable turns, but nothing heats up. After about 2 seconds of normal microwave sounds, a second, buzzing sound begins. After running for a few more seconds, I start getting a strong plastic smell. I have read about checking the waveguard, but I don't see anything inside my microwave that is removable for cleaning. Are there screws or something?
  • 1 more comment
  • Melissa Wunderly Apr 16, 2007
    Quick and thorough solution. Thanks!
  • Anonymous Mar 21, 2014
    when microwave is on no heat and smell bad like plastic burning
  • Anonymous Mar 25, 2014
    I put some food in my Maytag microwave oven on a microwave safe plate, set the timer for 10 seconds, started the machine, and immediately there was a cracking noise with sparks and the smell of plastic coming from the louvered panel just above the control panel. tried starting the unit again. It runs and is noisy but does not heat. It is a model no.mmv1153aaw ser. no. 51240173. Thank you.
  • GE Master
  • 9,098 Answers
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
Posted on Apr 11, 2007
My microwave has the same problem described in the post. I checked the linked bulletin and found my microwave is listed. I called the 800 number listed in this post and the person said there is no such bulletin. Is there another number I can call or is there an official bulletin I can get a copy of?
Posted on May 25, 2007
Buzzing sound... Turntable stopped. food heats up but uneven. No microwave fan when heating.. no light inside expensive fix?? Unit is 10 years old
If the microwave oven is 10 years old then it is time to consider a new unit, by your description it is going into cascade failure where different parts have stopped working, the buzzing sound is the magnetron warning you, it is about to fail. The fans job is to keep the magnetron cool while it is running.
Mar 08, 2011 | GE JVM1850 1000 Watts Microwave Oven
Are there any recalls on GE microwave JVM1540DN1ww Thanks, ssi96@aol.com
There are no recalls on GE over the range microwave JVM1540DN1WW but there SHOULD BE! Mine lasted only a year and a half and then started running and heating with the door open. Shortly after that it stopped heating at all. The light and fan works, and the keyboard lights up but the turntable doesn't turn anymore (yes I made sure the turntable was turned on), and it doesn't heat. It will count down like it's heating but it doesn't heat. Changing the door switches didn't work. Husband thinks it is the magnetron which is expensive to fix. I won't ever buy another GE microwave period! Check the web and you will see all the similar complaints. I just searched online and for a lesser price than I paid for the GE, Samsung sells one that has the one year warranty but also has a 10 year warranty on the magnetron.
Jan 25, 2010 | GE Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave turntable won't turn
Most likely the turntable motor itself is bad - not an uncommon problem for that model.
Check with www.martinmicrowave.com (toll free 1-877-894-0035)
unfortunately, the particular motor used in your model is rather expensive - + - $50
Dec 23, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave stopped working
to indutolia
The original problem was probably a bad turntable motor, which is pretty easy to replace.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too: http://www.microwavedisplay.com/doorsw.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
to lostonisland - Your problem is different enough that it should be a separate post. Please include your brand and model number when you repost.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
285 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
