Question about Abit NV8 (890552603459) Motherboard
Bios info retention
I reset date and usb keyboard settings but on restart I'm back to 2005 Presume possible old and depleted battery what battery do I need for replacing can't get info from Abit site links don't work. Pre-thanking you
Mel
  • 24 Answers
You can look at the battery to see what one you need. I think most modern boards require a CR 2032, but check yours just to be sure.
Posted on Dec 25, 2008
I bought a lenovo all-in-one pc at auction, the problem is the usb ports are locked on the bios, therefore i am not able to access my bios settings because usb ports are not detecting a keyboard
Some possibilities-
If there is a keyboard socket (mini-din), buy a cheap wired keyboard.
There is often a button on the motherboard that will reset the BIOS to default.
If there is a small battery on the motherboard, disconnect for a minute or so, and re-connect. This may reset the BIOS.
Feb 14, 2017 | Lenovo Computers & Internet
When i shut off computer, time and date reverts to 2003 , new battery etc when turned back on msi ms 7235 ver 1.1
There is not a lot of info, but I'm gonna go with the choice of a laptop, since you say "new battery". There is also another battery in the motherboard, also, you need to set the date from within the BIOS, if you don't set it from the BIOS it will always revert back to the date of manufacture.
Jan 07, 2015 | MSI Computers & Internet
How to unlock a keyboard on a dell inspiron 5737
I would like to have more info, but, you can try these steps. After
each step try keyboard for operational.
1-remove battery, open pc and hold power button for 10-15
seconds. This resets system board. Replace battery and restart.
2-restart pc clicking F2 key to access BIOS, choose default settings,
restart.
3-remove battery, with plastic flat scribe pry top of keyboard down
and up from casing, disconnect ribbon cable, remove keyboard, clean
keyboard thoroughly under keys. Replace in reverse order.
4-replace keyboard. Free if under warranty. Less than $100 if not.
Jun 09, 2014 | Dell Latitude D600 Notebook
How do I reset the Bios in my PC?
If you can get into the BIOS setup there maybe a setting to restore the BIOS to the default settings.
If not then remove the BIOS battery for approx 20 mins until the charge in the BIOS has depleted and the replace the BIOS battery. Then go into the BIOS setting and set the Date and Time etc.
May 20, 2012 | Computers & Internet
The USB and ps/2 ports are not working on power up. the keyboard and mouse are not recognized on boot up. The PC boots as normal to the desktop with no problems. All was working fine until i started...
I assume you have by now taken out the sound blaster card, I hope. The beeping is a code that tells you what the problem(s) are with your computer. Just taking out the sound card will be a start. If you had an onboard sound card and did not disable it first, then that is what started your problem. Try booting up and pressing F10 to get to the set up screen. make sure your ps/2 and usb are turned on. if you can't get it to work on your usb keyboard, borrow an old one and do the same thing. hopefully nothing permanent has been done. your bios should straighten back out. if this does not work with the old style keyboard, then open your case, you will have to find the reset jumper, very hard to find unless you have the board manual, or just lucky. Not able to do that, then find the backup battery, will look like a watch battery. Take it out carefully and leave it out for couple of minutes, reinstall and should be good to go. pulling the battery erases all your settings and returns it to bare stock settings..... let me know if more come up
Feb 03, 2010 | Computers & Internet
Laptop will not keep current date/time
The BIOS battery is nearly flat and this is causing the time to drift.
Replace the BIOS battery with a new one, then you will need go into the BIOS configuration to set the date and time.
Apr 30, 2009 | Sony VAIO Notebook
Boot up failure
It's possible you are using a USB keyboard and it is not being detected. You should be able to turn the caps lock light on and off if it is working. Try a ps2 keyboard.
Apr 04, 2008 | Computers & Internet
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
Compaq armada 4131T
hi,i presume that u cannot punch in the password as the keyboard is not working, except the Enter key, u can do two things, reset the bios, or repair the keyboard, by removing it and cleaning the contacts, to reset the BIOS, locate the small lethium battery, remove it and keep it outside for some time, then put it back,that will reset the BIOS.. try either of it.. let me know...
Dec 04, 2007 | Compaq Armada 4131T Notebook
Abit NV8 (890552603459) Motherboard Logo
46 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
