Question about Sanyo DS35510 35" TV
2" of horizontal lines at the top of the screen
This is actually a Sanyo DS35580.
The problem began about 3 weeks ago with 1" of lines. Now it is 2" and increasing daily.
  • judydore Jan 04, 2009
    Thank you Benimur. Is this capacitor a fixable or replaceable part?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, on most TVs, your described issue indicates that the Pump Up capacitor has slowly leaked and/or nearing end of life (dried up). This capacitor would be located very very near the Vertical Deflection IC and would be the biggest of the bunch of capacitor within that immediate area.
Good luck and Thank you for using FixYa.
Posted on Jan 04, 2009
  • Louie  Role
    Louie Role Jan 04, 2009
    Appreciate the postback.
    Yes it is replaceable. Rather an inexpensive component, should not take a couple of minutes to replace. What would be more challenging is identifying/locating it and getting access to the solder joints underneath the PCB (printed circuit board). Should look like image below (not necessarily same value/specs).
I have a Samsung 50 inch 3D Plasma TV (model number PN50C7000YF) that has recently started developing black horizontal lines across the top of the screen all in a 3 inch horizontal area. Every week I get...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Samsung PN50C7000YFXZA PN50C7000 3D Plasma...
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Horizontal lines at the top of the t.v. screen.
you will have to find fault in vertical deflection try condencer replacement in that stage
Jul 11, 2009 | Philips 27PT6441 27" TV
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
here's something you can try...remove the back and notice that there are ribbon cables (FRAGILE!) on the right and left side...alot of times these cables develope bad connections and cause the lines you see...other times the panel will be suspect. Removing these ribbon cables and reseating them have helped me determine in the past if it is a bad connection...or a bad panel
Jan 09, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Sanyo DS35510 35" TV Logo
153 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
