You can't. Either it came with them or not,.....yours didn't. It's like wanting to make a black & white tv into a color t.v. Although I used to get that all the time.....It's just a tube you pop in!!!! Sorry, the set has to be designed in the first place with that.
If your TV has an HDMI input, you just plug the chromecast cable into it. If the TV does not an HDMI input, there are several types of adapters that convert the HDMI to whatever the TV input is. I could not locate your TV on the web to see what inputs the TV has, but if you do a search on the web for " HDMI adapters" , you'll find several types. You just need to match the adapter to whatever input type is on the TV. Possibly a place like Best Buy may have the adapter you need. I hope this helps.....
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
TRY ON THE DISPLAY PS3 SETINGS TO NOT LET THE HDMI DO AUTOMATIC,,CHECK OFF A FEW ,,LIKE TRY JUST DION IT CUSTOM,,CHECK 480P,,AND 1080I,,,NOT 720P OR 1080P,,TRY THAT AND IF YOUR TV IS A 1080P,,JUST CHECK THAT,,OR IF ITS A 1080I,,JUST THAT
Try disconnecting the hdmI cable and the dvr box.
Connect the cable directly to the cable input.
Sometimes the dvr boxes will cause this problem
after you connect the hdmi cable.
KIT10 $29.50 Repair Kit for Hitachi convergence Chassis DP-14G KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
