Question about Janome Sewing Machines
Presser foot lever won't lower the foot
When I try to lower the presser foot, the lever goes down but feels loos and doesn't actually lower the foot. It will raise the foot to the upper most level but one't lower it. The lever itself moves freely but the foot doesn't move. It seems like something has broken off that should be grabbing the bar and pulling it down.
    Champion:
  • 243 Answers
This may be a lubrication problem on the presser foot shaft. Try freeing up with penetrating oil or Triflow. After letting set for an hour lower the presser foot and pull down on the ankle. If that does not work you need to open the machine and loosen the clamp screw on the presser foot shaft. Then try to twist the shaft to loosen it up.
Posted on Nov 25, 2017
2 Suggested Answers
Tally Girl
  • 1133 Answers
SOURCE: When I raise the lever the presser foot only lifts
yes, pressure foot lever should stay raised, this sounds like the spring has broken in your machine. if you are comfortable with delving into the machine you could open it up and take a look. alternatively take it to a sewing repair man and get it serviced as well as clean and lube.
Posted on Jun 26, 2011
Presser foot doesn't go down. Presser foot lever goes up and down but the presser foot does not. Singer sewing macine.
There may be a disconnection between the lever and the presser foot bar. Perhaps a screw has fallen out, broken, or is loose? May need to take it for service.
Sep 25, 2017 | Singer Sewing Machines
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
Presser foot lever no longer lowers the foot, just goes up and down
Sounds like the lever has become disconnected from the presser foot bar.
Nov 22, 2015 | PfaFF Quilt & Craft Pro 7530
Presser foot lever not working
does it feel loose and wiggly? A lever should feel firm as it works. If it does you'll need to get inside. Typically these levers have a cam on the other end that activates the presser foot bar. If it is loose it could have slipped off the part that makes that happen. Also the part on the presser foot bar can be broken but you won't be able to tell until you get in there.
Take your time and take pictures as you remove things. safeguard the parts... Good luck, I hope it's just loose.
Sep 07, 2012 | Toyota Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
Pfaff 6091 Presser foot won't go all the way down
HAVE THE 6091 MACHINE AND THE FOOT IS NOT FROZEN BUT WON'T GO DOWN. OILING THE MACHINE DID NOT HELP AT ALL. HAD A REPAIR MAN COME TO THE HOME AND CLEAN THE MACHINE. STILL THE FOOT WILL NOT GO DOWN.
Nov 21, 2011 | Sewing Machines
What instructions are there for a brother nx400 even-feed foot
Remove the screw holding the regular presser foot and the presser foot holder and set aside.
Place the take-up lever in the highest position.
Hold the even feed foot with your right hand with your thumb holding the lever of the foot in its highest position. Place the even feed foot on the presser bar and make sure that the lever of the foot rests upon the needle bar thumbscrew. While holding it in place, fasten the foot to the presser bar with the screw.
As the needle bar goes up and down, the lever on the even feed foot should rest on the needle bar needle serew and go up and down as well.
Jul 19, 2009 | Brother Sewing Machines
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
"Lower presser foot" error on SE 270D
This happened to me and I eventually realized that there is a small door flap at the top near the "4" in the threading series that can get stuck open. Normally this flap goes up and down with the presser foot, but if it gets stuck open even when the presser foot is down, tapping it or closing it manually will make the error go away.1_9_2012_12_19_55_am.jpg
Dec 28, 2007 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
149 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
