Question about Compaq ViewCast Osprey 100 (388279-B21) Video Capture
Osprey 100 capture card Vista 64 driver
I this
  • Anonymous Mar 06, 2009
Windows 7 drivers
They should have a windows 7 driver. I suggest that you contact Viewcast Tech support.
Apr 11, 2013 | ViewCast Osprey 210 Video Capture
My Dazzle DVC 100 wont show up in the drop down menu in Capture source.
Welcome to Fixya,
It will not showed up if your Windows is Vista or Windows 7 64 bit. If ever you need to download and install the driver for your dazzle Device. You can download it to Pinnacle website.
Aug 08, 2010 | Pinnacle Dazzle DVD Recorder
Easycap i can't intall thediviceEasycap capture model no..DC60
I have checked these files and they appear clean to me.. please exercise caution and scan them yourself.
32 bit driver
UNOFFICIAL 64 bit driver
64 bit Vista and Windows 7 driver
Aug 05, 2010 | DekCell EasyCap USB 20 Video Capture...
Where can i get a dirver for Osprey 50 for Vista or Windows 7
I am afraid if its' Osprey 500 or 50, I am sorry if i am not right. Anyway try this site, and download the drivers. Good luck
May 22, 2010 | ViewCast Osprey 50 Video Capture
Hi,i have the problem with Audio device on my Osprey 210, video works grate..but audio don't work.... help'
Here's an easy way to install or update your sound card driver:
Use this driver scanning tool, which scans your computer for the needed drivers. It has an option to automatically retrieve them for you.
You can download this free tool from here or directly from this link
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
Hope that helps,
For Windows XP Driver Files and How-to Resources, visit XP Drivers
Mar 24, 2010 | ViewCast Osprey 210 Video Capture
Does moviebox usb work with studio 14 and vista? I can't get my camera to show as an import device when connected to the movie box.
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
  • 710-USB
  • 510-USB
  • 700-USB
  • 500-USB
  • MovieBox Deluxe
  • DVC-103
  • DVC-107
  • DVC-100
  • DVC-90
  • DVC-130 (There are no 64-bit drivers for this product.)
  • DVC-170 (There are no 64-bit drivers for this product.)
PCI based
  • 700-PCI (a.k.a. Pinnacle Studio Deluxe 2)
  • 500-PCI (a.k.a. Pinnacle AV/DV)
  • Any 1394 cards.
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
Dec 07, 2009 | Pinnacle Studio MovieBox USB Video Capture
Phillips SAA7130HL TV Tuner VISTA 64 BIT DRIVERS
well i had the same prob, so i downloaded drivermax, which I think is free.
drivermax scanned my computer and found all the drivers I needed including the vista philps tv tuner driver.
another way is to download iobit advanced system care which is an excellent free program and click the utilities button and then click drivers update. This should give you the philips driver as well.
hope this helps
it certainly worked for me
anyway you should be able to use the 32bit xp driver.
regards peter
Jan 23, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Osprey-230 video capture card distorted
you must connect all cameras to solve this problem.if your capture card supports e.g. 4 cameras and you are only 1,2 or 3 connected the image can be poore.your video card has nothing to do with this.
Aug 28, 2008 | ViewCast Osprey-230 (OSPREY230) Video...
Incompatible with Vista 64-bit
Eine Lösung die geht ist ein 2. kleinPC mit winXP32 den über Remotedesktop anbinden. Das ist komfortabel und funktioniert garantiert immer.
Aug 26, 2008 | Canon DR 2080C Path-Through Scanner
The microsoft doesn't identify the osprey 230
since the audio works but not the video, it sounds as though the problem might be in the codec, not the driver. check card provider to see if there is an updated codec pac or new service pac. try:
Mar 25, 2007 | ViewCast Osprey-230 (OSPREY230) Video...
Compaq ViewCast Osprey 100 (388279-B21) Video Capture Logo
393 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
