Question about Cranium Hullabaloo Square Tin
I can't get my daughter's Hullabaloo working
The batteries are good-I hit the button next to the batteries and nothing happens.
  • djfamily Jan 17, 2009
    I RESET IT WITHOUT THE BATTERIES BUT IT STILL DOESN'T WORK. I DON'T KNOW IF IT WAS DROPPED, ETC OR NOT.
  • 28 Answers
Remove the batteries & press and hold the button again for 60 seconds. This will ensure that the capacitors in the unit fully discharge. Replace the batteries in the correct sequence and try to power on the unit again. Without further information (was the unit dropped, immersed in water, were the batteries ever put in incorrectly) I cannot offer you another solution.
Posted on Dec 23, 2008
  • Julie Turner
    Julie Turner Aug 07, 2014
    My daughter dropped this game and it stopped working... any advice?
Hit the start button and nothing happens 2008 750 brute force
Check your starter solenoid. You can trace it by following the power wire from the battery to the small solenoid block that contains a 30 amp fuse. You can bridge the posts on the solenoid by using needle nose pliers or whatever else you may have. If it starts up or you hear the starter run, you have a bad starter solenoid.
Feb 02, 2016 | kawasaki 2008 Brute Force 750 NRA OUTDOORS
Will not power up
If you tried to reset it and nothing happened, the battery may be dead. This happened to my daughter's Garmin GPS twice. I replaced the battery and bingo! I never understand why the unity needs a battery even when connecting it to the car's power cord...
Mar 14, 2014 | Hipstreet Audio Players & Recorders
Daughter hit a curb with a ford focus 2005 now the battery wont stay charged. Replaced battery all was fine started the next day. After driving the car died nothing worked got a jump and car ran like no...
1. Check all the cable connections on the battery and on the alternator.
2. If they are all fine then have the alternator checked because from what you have described it is not charging. The usual problem is worn brushes in the alternator.
Dec 22, 2012 | Cars & Trucks
2003 VTX Ran Yesterday, today hit the start button and nothing happens. Had the battery checked and its good. The F1 light comes on and you here it priming but after that when you hit the start button...
sounds like you have a bad ground somewhere on the frame.I know there is a ground on the frame just in front of the battery and one on left side under front of motor factory painted the frame and they just bolted up the wires need to clean paint off and retighten. might be the problem
Apr 03, 2011 | Honda VTX 1800 Retro Spoke Motorcycles
2002 Passat I hit the ignition nothing happen. I
Sounds like you need to clean your battery connections.Next time it happens, turn your headlight on and wiggle the battery treminals, and if the lights come on, thats your problem.
Jul 10, 2010 | 2002 Volkswagen Passat
Will not come out of hibernation --I left it hibernating for a few days and now it won't wake up. Hard drive light blinks briefly when I hit the power button but nothing else happens. Battery and power...
Please remove the Battery from the Computer and clean the metal contacts.
Next, press and hold the Power button on the Notebook for 30 seconds before inserting the battery and turning it ON.
Good luck!!!!!!!!!!!
Sep 28, 2009 | IBM ThinkPad T30 2366 Notebook
Dell xps1530 laptop will not power down at all!
Ok - dont panice
FIrst start it an HiT F12 - then select diagnostics and run then - if it runs though good - your hardware is OK.
Next restart and as the machine bleeps hit F8
Select safe mode and see if it starts that way.
If it does cool. SO now run a disk check on the main drive (c:\) by right clicking on it and selecting "properties" and then TOOLs tab and then DISK CHECK - check the box automatically fix errors and let it run
WHen done see if it will restart ok
If not drop me a mail m.g.woodruff@googlemail.com ;)
Mark
Aug 28, 2009 | Dell XPS M1530 Laptop
Lost the instructions on how to play cranium
The instructions say to remove your shoes, spread the 16 pads around, about two kid feet apart (separate colors/shapes as best you can). Put the hullabaloo game nearby and turn it on, button near batteries. It gives the instructions as you go.
Dec 25, 2008 | Cranium Hullabaloo Square Tin
Setting up 2nd wii remote
Greetings mlsaenz7,
You need to resynch the second remote to the Wii console. To accomplish this you need to hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
Cranium Hullabaloo Square Tin Logo
170 people viewed this question
Top Cranium Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Cranium Toy Expert? Answer questions, earn points and help others
