Question about SanDisk Sansa e260 MP3 Player
Snasa e260 wont load up
When I turn on my sandisk e260 it starts up but it won't load, it keep's restarting itself. I held the menu button for 15 seconds and it turned off. When I turn it on it does the same thing.
  • robert_ly Feb 09, 2009
    IT THE PAGE DOESNT WOOORK!! XDDDD
The link for the firmware does not pop up it just says sorry your page.....
Posted on Sep 16, 2007
    Scholar:
  • 47 Answers
Hi. Your Sansa E260 might be encountering some system errors and would need a Firmware re-flash by setting it to its recovery mode. Try this: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again. I hope this helps. The E260 is a great player.
Posted on Apr 24, 2007
SOURCE:
My sansa san disk mp3 player wont turn off when not connected to pc. when it is connected it keeps going from saying connected, disconnected and writing all in seconds. when it is connected to the pc it...
First lets try resetting your player, to reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Next; if that does not help click on this link and down load the Updater program and update the players firmware.
http://kb.sandisk.com/app/answers/detail/a_id/156
Oct 16, 2010 | SanDisk Sansa e260 MP3 Player
When I go to turn on my mp3 it takes a while then restarts itself over and over...it's happened before but resolved itself somehow?
This issue may be resolved by resetting it, try this.
Resetting the device:
Jan 02, 2010 | SanDisk Sansa e260 MP3 Player
My sandisk sansa e260 mp3 player is always freezing . when i turn it on it pops out a window that says "refreshing database" . then stops and only load 15% of it .
As you may have noticed already, the player can be switched off when freezing and put on again, resetting the device as next:
Sometimes a firmware update or reinstallation is required, to get the player function normally again, see:
http://kb.sandisk.com/app/answers/detail/a_id/306
Need more help ? Just post a comment.
Dec 03, 2009 | SanDisk Sansa e260 MP3 Player
Screen says "Disconnected" and won't turn off. or load
Try these 3 resetting steps:
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 30, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 MP3 player is completely frozen up
hold it for about a few moments. so it can like reset.
Jul 04, 2009 | SanDisk Sansa e260 MP3 Player
Once i turn it on i cant turn it off and when i go to listen to music it just goes and restarts itself
Sounds like it's froze and needs to be reset. -
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
If that don't work let me know so i can try something Else?
P.S...Please rate accordingly...
Thank you
Computerrep
Feb 09, 2008 | SanDisk Sansa e260 MP3 Player
It doesnt want to load help!
Hey chave, I have 3 of these players in my home and every time there is a problem with them we find that if we HOLD the power button in and keep it in until it shuts off (while the button is still pressed...)can take a minute or more, it seems to reset any problems we have encountered. worth a try
Jun 05, 2007 | SanDisk Sansa e260 MP3 Player
Black screen blue ring
Try holding the Menu button for about 15 seconds.
Apr 01, 2007 | SanDisk Sansa e260 MP3 Player
My Sandisk e2600 won't turn on...please help.
If you have tried rebooting it over and over and getting no where it sounds to me like you will have to format i'm afraid :(
Mar 01, 2007 | SanDisk Sansa e260 MP3 Player
My sandisk e200 wont start
Hold on the menu/power icon for 15-20 seconds, it doesn't matter if the hold icon is on, this will reset your sandisk e200. if this doesn't work, then you might want to take it back to the store you bought it from.
Jan 07, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
245 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
