Code to progarmme Tevion TV
I'm trying to progarmme my Sky remote to work my Tevion 3221TS tv, but cannot locate the code. Can you help ? I cant find the remote code for sky for a tevion 32" md31134
SOURCE: tuning sky into the tevion 3241ts
Customer Support are taking peoples names when thay have the code for Tevion model 3241TS, they will either call you or email you with the code, reference hissing on low volume, yes my set does this, I have called Support Services, they do a one for one exchange, i.e. a courier brings you a new t.v. and takes the old one away at the same time, I'm in the process of doing this now.
Thanks
Steve
Posted on Oct 17, 2008
carlsbiz
  • 1124 Answers
SOURCE: Code to progarmme Tevion TV
Might be a bit late - but I hope this helps..
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
Posted on Sep 23, 2009
kitquint
  • 40 Answers
SOURCE: got a tevion lcd3219id tv but cant find sky codes
You may be better looking for alternative versions of your TV, it is unlikely that Tevion is the only version of that set, there may be a code for a different manufacturer which works.
Unfortunately there are probably many of the newer flat panel TVs for which there are no codes yet. Try _http://www.urcsupport.com also try codes: 1326 & 0065, they are very commen codes.
Posted on Nov 05, 2009
SOURCE: tevion lcd3207 cant find sky code. i am trying to
i have buy LCD TV for Tevion 32'' LCD Tv model LCD3207 PCB board 25114386.pls contact my e-mail
E-mail address: Kamfozi101@hotmail.com
Posted on Dec 27, 2010
SOURCE: Got a Tevion HDSR 600
I have the exact same problem. After a week, I lost all reception on the 10733 H 22000 transponder and (from memory) 10823 which means no BBC1, BBC2 or CBEEBIES which are a must in my house. I have used another set-top box and received those channels without a problem, so it would seem that the Tevion decoder is at fault and needs returning to ALDI
Posted on Jul 11, 2011
Sky remote code for tevion tv model 43858
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 16, 2012 | Tevion Televison & Video
Need a code for a tevion lcd 32081D to activate sky remote
Hello
Check these codes.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
Oct 16, 2011 | Televison & Video
Does anyone know the sky remote code for a Tevion 3221TS?
Hi here is a list of codes for tevion as supplied by sky>
1287 1326 1584 1165 1065 1696 1276 1317
Feb 01, 2010 | Televison & Video
Tevion LCD3210ID remote codes - Please Help
i cant get anything on my tevion television/dvd
May 22, 2009 | Televison & Video
Still looking for code for tevion 3221ts
Hello
try one of these codes
065, 696,726
please let me know the out come
Apr 08, 2009 | Televison & Video
Good luck..
Jul 22, 2008 | Televison & Video
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Omega urc-08 device codes
Original link no longer working. Found this: http://files.remotecentral.com/download/220/urc08-manual.zip.html
Comment if it's wrong one.
Nov 22, 2007 | Televison & Video
Sky+remote code for my lg tv
The cose you need is 0206
Sep 15, 2007 | Televison & Video
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
