Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint dishwasher model BFI62
Dishwasher is starting the cycle and theres no water coming through! Cleaned all filters and checked inlet pipe I cant get to the back of the actual dishwasher as its in built to the units. The light is stuck on the heavy duty cycle and flashing rapidly. Any ideas need my dishwasher for xmas day as large family to feed and dont fancy the washing up!
Many Thanks
xx
  • zdhbjones Jan 04, 2009
    Hello - i have the same problem as described above - is anyone able to help.
    Deano.
Water leaking into base of machine. tip dishwasher back and drain out water. then check all seals intact, i.e. around arms, around salt holder etc
Posted on Feb 03, 2009
Detergent not dissolving therefore some items not clean.
Jerry had two good First Checks with the water level and the temperature. Turn on the dishwasher and open the door after it completes filling and check the level and temperature.
A third possibility if the level and temperature are correct is that your dishwasher is not spraying enough water around. This could be due to a faulty pump, but more often I see a reduced spray from a clogged filter on the input to the pump.
You can check the amount of spray by waiting until it starts the wash cycle and open the door quickly. Water should be pouring off the upper rack and you should either have water come out of the door or have it be very close to spraying out.
Some dishwasher models have an easily accessible filter, others take some tools to get down to it.
Mar 31, 2015 | Hotpoint Dishwashers
Hotpoint fdw85 does not drain
sounds like the pump is not working
Jun 11, 2017 | Dishwashers
Hotpoint LFT 228 A dishwasher intermittent draining problems. Sometimes so much water that it leaks, will drain sometimes but then water appears in the filter again, items in dishwasher sometimes come out...
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
Sep 25, 2011 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Water fill problem on Hotpoint Dish Washer Deluxe Model DF 31
Pl check the small filter fitted near the water inlet hose. Probably you may have to pull this filter as this is housed in the threaded pipe attached to the body.
Remove the hose from the machine and try flushing. see whether you get sufficinet pressure from over-head tank!
Clean the filter with tooth brush or reverse clean. Do no for get to fit rubber washer.
Mar 30, 2010 | Hotpoint 24 in. DF55 Free-standing...
All filters are clean, but water will not come in
Hi, Check the float in the front corner and make sure it moves up and down freely. Also, you can check voltage at the inlet valve. It should get 120V at the start of the wash cycle. If there is voltage, the inlet valve will need replaced. If there is no voltage, the float switch needs tested. It is usually the inlet valve or the float.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Bosch 24 in. SMU70 Built-in Dishwasher
Hotpoint Superplus 7822 dishwasher
At the beginning of the cycle the dishwasher is attempting to pump out any residue water in the waste pipe and sump. It could be that the motor is sticking but you would probably also suffer from it not draining properly.
It may just be noisy pump. I have a similar model and it is also quite noisy but nothing extraordinary.
When the dishwasher is pumping out at the end of the washing cycle it may be quieter when there is water in the pump/pipes but then gets noisy as it 'pumps air'.
Jan 29, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Flashing lights
Not heating, check element and thermal fuse/thermostate. Regards Advisor
May 30, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
315 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
