Question about Polaroid PhotoMax PDC 2150 Digital Camera
Battery cover The cover for my batteries will not latch shut. I can tell that a tiny piece of plastic has broken off. I would like to contact Polaroid to see if this can be taken care of by them. Does anyone know how I can contact them directly or any other ideas? Thanks much... Bobsoldlady
SOURCE: I need a battery for a Polaroid t737 digital camera
To purchase accessories for digital and digital video camera model numbers beginning with: a, i, Ion, izone, m, t, CAA-04030S, Studio 4, x530, PDC (except PhotoMAX PDC models listed above) and Polaroid Pixie cameras, contact the number listed below-- Polaroid Digital Camera Support
USA / Canada: 1- 877 - 388 - 3779
Hours (EST): Mon-Fri 10am - 7pm, Sat 10am-4pm
Available accessories include -- batteries, USB and video cables, image editing software and other items that were included when you purchased your camera. Note: Accessories may not be available for some older camera models.
Posted on Jan 13, 2009
0 characters
1 Points
Can I replace the latch or change the full internal chamber?
this part is available with Nikon agency, to replace this you have to open the whole camera, then detach the front portion, it doesn't matter, just a piece of rubber or sponge fix on the battery lid, this will be help full to hold the battery at contact perfectly.
Jan 09, 2016 | Nikon 1 J1 Digital Camera
Nikon D40x camera flash faulty
Depending on exactly which piece is broken, you can order the flash top cover and/or the flash head assembly.
Dec 24, 2011 | Nikon D40x Digital Camera
The latch for the battery cover on my Power Shot A720 IS is broken. Can it be fixed?
Probably not as the cause is most likely broken molded plastic parts that where to small and thin to last very long. Seems to be a common problem on this otherwise great pocket camera. Use tap or a rubber band to keep the battery cover closed so the contacts still work. Bad design by Canon.
Jan 03, 2011 | Canon PowerShot A720 IS Digital Camera
Canon G3 camera just stopped working completely
Do you have a way to test the battery and you know it's ok?
Those batteries have built-in protection circuitry that can cut out or turn off the battery entirely if it detected a problem like a short circuit, etc. And it may not get over it.
Try a 2nd battery or the AC power adapter directly.
Also check that the 3 little pins in the camera DC input jack are intact, straight, and not touching each other.
Some camera's won't turn on if the memory card door is open or the card is ejected but I tested that on my G3 and it still turns on either way.
Ah.... and lastly... there is a little electrical limit switch connected to the battery cover door that disables the camera if the battery door is open. It gets pressed by a small plastic piece attached to the battery cover when you close the battery door. If the plastic piece or the tiny, recessed switch has an issue then the camera won't turn on The switch could be bypassed internally (not easy to do) if that was the problem.
Look for a tiny, thin, black plastic switch about as thin as a staple down in a recessed hole (slot) near the battery cover hinge. Try gentle pushing the battery closed switch "over" a little. You can tell which way to push by observing how the battery door slides into position as you close it. I was able to turn on my camera with the door open by doing this.
The switch is very tiny, don't break it.
If the battery door isn't closing all the way that would also cause the same issue.
Feb 18, 2010 | Canon PowerShot G3 Digital Camera
The battery door will not clamp shut.
Only way is to replace the part with a genuine accessory.It won't be of a big cost.Please contact your nearest authorized service center.
Oct 03, 2009 | Olympus FE-140 Digital Camera
Camera door thats holds battery small grey latch is broken
Try they might be able to solve your problem. Also look at the latch and determine if it is attached to the front of the camera case or the back of the camers casing I am assuming it is attached to the back then you might consider caling HP back and ordering the Back or Front cover Assembly. Small pieces like this usually don't come by themselves you have to order an assembly, so when when u call for parts ask for Back cover assembly or front cover assembly, which ever it is attached to or apart of. Asking for a perticular piece they will not usually know what you need. You have to talk to them in technical terms.. Hope this helps you out...
Sep 21, 2009 | HP R967 Digital Camera
Cover card open when it's shut
This problem is caused by the little piece of plastic that you flip down to hold the XD card in place. It has a nipple sticking out of it that is prone to breaking off. Unfortunately, this nipple (about 1/16" x 1/8" x 1/8") holds down a little button which tells the camera that the the plastic piece has been flipped down. Once the nipple breaks off, you need to find some other way to hold the button down.
I simply took a small plastic peg from an old boardgame -- a cribbage-board peg might work -- and whittled it down to fit the opening. Remove the XD card and you'll see the small 1/16" x 1/8" rectangular opening. There's a tiny, squarish black button inside. Use a toothpick or tiny screwdriver to carefully press the button in while the camera is on, and you'll see the error message disappear.
Once you get the idea, use a tiny Phillips screwdriver to remove the plastic piece that you flip down. There are two screws to remove, two little metal retaining brackets and a tiny metal rod. Be careful not to lose any of these pieces! Then gradually whittle your piece of plastic so it fits the rectangular opening snugly, and consistently turns off the error message. Then cut it to about 1/8" in length, insert it into the opening, and reassemble the rod, brackets and screws to hold it in place.
Now the little button will always be pushed in and the camera will be functional once again. Since the XD card has its own spring-loaded "locking mechanism" (you push to insert and push to remove), the piece of plastic you flip down isn't really needed in the first place. You can save it, anyway, just for the memories....
Apr 05, 2008 | Olympus Stylus Verve S / ?-181 mini S...
Faulty Latch Sensor
in the bottom corner of the latch there is a little piece of plastic on the hinge that pushes a switch that tells the camera the latch is shut if thats broken off thatll be the problem id shove a piece of a matcher in to see if it does the trick and if so its a new latch or leave the matcher :) 5
Sep 12, 2005 | Fuji FinePix S1 Pro Digital Camera
Polaroid PhotoMax PDC 2150 Digital Camera Logo
Top Polaroid Digital Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Digital Camera Expert? Answer questions, earn points and help others
