Question about Denon AVR-1907 Receiver
No dolby or dts surrond
I ve had my denon 1907 for just 18 months and now have no surround sound just the sound track and no speech. The input via coax of fiber optic cable shows am recieving dolby signal .have also tried direct input from dvd player this does not work.Also when doing a test signal to each channel from dvd no sound.Could this be a problem with the decoder is this an expensive item? when using the radio on fm no sound on stereo but if switch to 5 channel you can hear sound back speakers only.|Hope you can give me a little idea as what could be wrong or any other suggestions
many thanks mikev
  • wrightyr9 Mar 23, 2009
    my problem the 1907 shows its reciving a dolby signal (skyhd/ps3) but only the music comes out of the speakers no voice. through both optical ins. so know its not one of those at fault. help......
5 Suggested Answers
  • 119 Answers
SOURCE: Denon AVR-688 Dolby Digital issues
IT IS ALWAYS BEST TO CONNECT ANALOG AUDIO IN ADDITION TO THE OPTICAL, COAXIAL OR HDMI AUDIO CONNECTION. IF USING OPTICAL OR COAXIAL CONNECTIONS BE SURE TO CONFIGURE IT IN THE RECEIVERS DIGITAL ASSIGNMENT AREA IN SETUP.
ALSO, ON THE FRONT OF THE RECEIVER IS AN INPUT MODE BUTTON, PRESS THIS BUTTON UNTIL AUTO IS DISPLAYED
Posted on Mar 03, 2009
SOURCE: No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Posted on Apr 12, 2009
SOURCE: Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Posted on Jul 20, 2009
  • 128 Answers
SOURCE: Hi,
The processor that creates the surround is all on 1 chip so sounds like a software issue.
Call Denon to see if they have a firmware update for your unit this usually is free and may fix the problem
Posted on Feb 19, 2010
How can i connect my denon 5805ci with my new tv 4k & 3D sony 65"
Are you sure that model is HDMI v1.4 compliant? I know my Denon 8508 is not so I use optical outs to get 5.1 surround sound.
Sep 08, 2014 | Denon AVR-5805CI A/V Receiver Dolby...
Sound stops when listening to Pandora via Samsung LED Pandora App.
Is the TV connected to the receiver with a digital connection (coax, or optical)?. Try setting it to PCM on the TV Some receivers don't like it when there is a break between tracks and the signal is lost. You won't get surround (but Pandora is just stereo anyway), but you can still use the Receiver's Dolby or DTS features to go multispeaker. Downside if of course that if you have other Multichannel audio sources through the TV, they may be lost. But it's worth checking..
May 13, 2014 | Denon AVR-E400
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
Hi, I have a denon 2802 av receiver. My Dolby decoder seems broken, the doby-display-indiactor is blinking as soon as a dolby signal is receiced. resettting doesn't help. DTS is still working. Anaybody...
Feb 13, 2010 | Denon AVR-2802
Cannot get dts surround. I am using a PS3 and the
DTS (digital theater systems) is the name for a company that has it's own proprietary digital encoding for the audio, just as Dolby Digital does. In order for your media to have audio output in DTS, it actually has to be encoded with the DTS software format, AND manually selected by the user to play in that format. Incredible Hulk is NOT encoded in DTS. Select a movie that has the DTS encoding by checking the rear label of the case on the format table.
Dec 30, 2009 | Denon AVR-1603 Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
Not getting dolby digital or dts
Not available on this unit...accordianman
Feb 06, 2008 | Chaintech AV-710 7.1 Channel PCI Sound...
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
Denon AVR-1907 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
