Question about Epson Perfection 1660 Photo Flatbed Scanner
Flashing red light & noise
I have a flashing red light and a wild noise when i turn on the scanner, need help asap :)
  • soup331 Dec 29, 2008
    I have the identical problem Plug it in...the red light flashes and you hear "clack...clack...clack...."
  • nccrow Jan 07, 2009
    Exactly the same here...
I've just discovered that this means the "transportation lock" is on: at the back of the scanner, put the plastic switch into the 'unlock' position. See this Epson support page for more details.
Posted on Jan 07, 2009
4x4 light flashes red whilst driving
You need to take this car to a mechanic to get it checked ASAP. Could be a serious problem with the car.
Apr 28, 2014 | 2001 Mitsubishi Montero
The scanner is connected properly and I've used it for years. I turned on the scanner today and the power button on front lights green, then I hear a jerking sound and the light immediately starts...
Check if the transportation lock is in the unlocked position; this is on the back above the USB port. Disconnect any accessories that could be malfunctioning. Then turn the unit off and back on. If the unit responds properly, it was a temporary problem. Retry the accessories. Otherwise, the unit needs service. You will need to determine if the cost of service is worthwhile.
The flashing red light can indicate the fluorescent lamp needs to be replaced or the scanner is malfunctioning. From the sound you describe, I suspect it could be a problem with the motor or the path that the scanning unit has to travel.
I hope this helps.
Feb 11, 2011 | Epson Perfection 3170 Flatbed Scanner
6 yr old 30 sharp equos. When I turn on red light flashs green and turns back to red immediately and no picture.
I have the exact same problem. Check to make sure the AC power box isn't making a ticking noise. It could indicate a faulty box. I'm getting mine checked out asap. I'll let you know how it goes!
Jun 19, 2010 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
PS3 shuts down after one second
hi , i hate to say this but you need to do this asap. Call the playstation support line and send it in. your ps3 is experience a corrupted hard drive. This will only get worse and will eventually shut down for good.
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
Red light flashing and noise
The user manual states the flashing red light signals that your transportation lock is on. Look underneath the scanner and you'll see a switch for "lock" and "unlock." If the switch is turned to "lock" move it over to "unlock" and plug the usb cable back into your computer. It should work with no flashing red light. If not try restarting your computer and plugging it back in again.
Mar 30, 2009 | Epson Perfection 2480 Photo Flatbed...
My Epson Perfection 4990 indicator light is flashing red shortly after the scanner is turned on. The manual says that the light tube needs replacing. How do I do this or is it a professional repair?
I had the same problem and first checked the instructions in the Epson manual on the red flashing problem, read the following pdfs: Indicator light or problems
I saw the fluorescent lamp come on for a second before the indicator light started to flash red, so I knew that the lamp was ok and did not need to be replaced. Try this turn off the scanner and try unplugging the transparency lid from the back of the scanner, turn on the scanner and see if the light goes back to green. My issue turned out the be the mechanism inside the transparency lid, I kind of heard an awkward noise when I turned on the scanner, but thought it was coming from the base, I rlocked and unlocked the transportaion lock on both the base and lid, to see if that would fix it but it turned out it was coming from the lid, where there is also moving parts inside using a belt and wheels. On the end wheel closest to the front, the 2 little plastic pegs that hold down the square metal plate with wheel broke off, I could hear them inside when I lightly shook the lid, anyways I opened up the lid by removing the 5 screws and you need a screwdriver to put in each of the little openings around the edge to pry open the lid. I removed the belt and metal plate, watch out there is a spring attached to it, don;t forget how this part works when you put it back on, I found both of the little broken pegs and glued them back on with a strong plastic epoxy glue that I bought at Ace Hardware, I let that dry for 24 hours and then put the metal plate and wheel on then put the belt around the wheel, and now everything works fine.
Mar 06, 2009 | Epson Perfection 4990 Flatbed Scanner
Tv won't turn on, keeps flashing red, will not turn a solid color
Sounds like the lamp needs to be replaced.
Before any repair or replacement, unplug the tv from the electricity for an hour, plug it in. This forces a system reset on the tv and may solve the problem. More likely you need a new lamp.
Aug 17, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Epson Perfection 1660 Photo Flatbed Scanner Logo
1,288 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
