Question about Brother IntelliFAX 2800 Laser Fax
Fax machine sleep mode
I have a Brother MFC 7420 fax machine that says it is in the sleep mode. I cannot receive any faxes, and cannot get it to remove the sleep mode, although I have tried to set up the "quick receive" function and it says it is accepted
    Champion:
  • 320 Answers
Have you tried to unplug the machine from the wall and then plug it back in this reboots the machine
Posted on Jan 16, 2009
I have a brother MFC-7430 all-in-one - Fax won't work
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Hope this helps. Please rate my response.
Thanks.
Mar 15, 2010 | Brother MFC 7420 All-In-One Laser Printer
Won't fax
You have to get your answering machine and your fax to play nice. Read the instructions for both. I think I have my answering machine to pickup at three rings, and the fax to pick up at five. Don't have the fax answer first. Don't have both machines answering at the same number of rings.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 doesn't receive faxes - send out is OK
If you have the book, go through the setup procedure as if you were installing it for the first time. If you don't have it, go to the Brother website and download it.
Mar 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
Can send but can't receive faxes on MFC-8460N
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Feb 09, 2009 | Brother MFC-8460N All-In-One Printer
All-In-One Brother 7420 not receiving faxes on home phone. Am trying "easy receive" but all it does is ring... (FYI: I cannot get distinctive ring on my phone). Have already tried Fax/Tel mode but would...
try leaving easy receive on and changing the receive mode to manual. when you pick up phone and hear the other faxs' tone, wait for your machine to take over by listening for the chirps. then hang up. if you don't hear chirps from your machine, then press *51.
hth,
razors
Dec 29, 2008 | Brother MFC 7420 All-In-One Laser Printer
My brother mfc7420 won't send or receive faxes.
please give me more info! what is on the screen? i am a brother tech, i will try and help you but i need mmore info.
Dec 16, 2008 | Brother MFC 7420 All-In-One Laser Printer
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Set up to receive fax
It does not matter, it should wake up as soon as a fax is coming in, the problem is most likely that the fax set-up was improperly done. There should be a setting to tell it when to pick up, after two,three or four rings, if you have an answering machine, time date. Those need to be set-up for it to work.
Sep 04, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother IntelliFAX 2800 Laser Fax Logo
568 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
