Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Saying to close door and we already have
Keeps saying to close door and we already have
  • Hotpoint Master
  • 3,463 Answers
When you shut the door , do it very firmly until you can hear the latch click, if it still will not start, then you could have a faulty door lock or a communication problem between boards.
Plz rate my solution.Thanks.
Posted on Dec 23, 2008
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
GP215 Canon Photocopier says close front door when its closed!
THIS PROBLEM DUE TO YOUR COMPOSITE POWER SUPPLY PROBLEM
Nov 28, 2013 | Office Equipment & Supplies
Door won't lock for self cleaning although closed
Hi, Look to see if the safety switches in the slots in the door is bent Kind of hard to figure out if you don't know how they are supposed to look like but guess remember it's not working either, also could be a bad switch itself.
Nov 22, 2011 | GE Profile JTP56 Electric Double Oven
Garage door close but motor keeps running
The close setting limit switch needs adjusted. Once it is adjusted it should work just fine.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Machine keeps giving error message that door is open or cloths are blocking when this is not the case and won't start
you might have a defective door switch. this is the part that locks the door and sends a signal to the processor to say that the door is already closed.
check also the wires that goes to this door switch. it could just be loose connection.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Bosch Washing Machines
Error message
Simply open and close the door.
Look in the LCD is the door indicator off?
Jun 01, 2008 | Epson Stylus Photo R300 InkJet Printer
Printer says door open
aah simple solution to that modiboni. you need to check if the printer door is still open but youv already tried that im sureoption 2 im not to sure on your printer but when you open the door chek to see o protruding plastic that will activate a switch to say the door is closed if you see that the plastic is broken use a small item to push down the sensor and it hopefully should read that the printer door is closed.
May 13, 2008 | HP Deskjet F340 All-In-One Printer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
112 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
