Question about KitchenAid Pro Line Coffeemaker Coffee Maker
E2 message won't go away Mine gives an E2 or E3 error code. Problem is that this started the 2nd day after I bought it! I had another one before this and had purchased it when they first came out. A while went by and it was giving the error code. Got rid of that one after having it for less than a year. I've cleaned the one before this MANY times, cleaned this one also (even though it was brand new) and still the problem. Do you have any other ideas???
  • sparky075 Dec 24, 2008
    My Kitchen Aid Pro Line coffee maker shuts off and gives an error code, E2 or E3. I turn it back on and it shuts off again. Eventually it will brew but sometimes not the whole pot. I had this coffee maker before and was having the same problem so I bought another and it started doing it from the 2nd day on.
    Novelist:
  • 171 Answers
An "E2" error message on most kitchenaid appliances usually indicates a temperature problem. The device is detecting too hot or too cold conditions to operate. A lot of the time it's just the sensor itself that's busted and not an actual overheat, but it's there as a safety precaution.
Typically the thermistor just needs to be replaced, but on a coffeemaker I'm not sure if the thermistor can be easily removed. Certainly not by a consumer.
If the appliance is new, you my want to return it to the store you got it from. If you can't do that, send it in for warranty repair. You can't replace the thermistor yourself but kitchenaid sure can..
Posted on Dec 24, 2008
  • Frosty555 Dec 24, 2008
    Yeah, they don't tell you what the error means in the manual but it's usually the thermistor (temperature sensor). They just suggest you send it in for warranty and don't give you the gory details.
    Call 1-800-541-6390 and ask for a "hassle-free replacement". They will mail you a new unit, and you ship your broken unit back in the carton the new unit came in. The only thing they require some kind of proof-of-purchase... e.g. a photocopy of your receipt.
    Genius:
  • 1,011 Answers
Sir,
Click this link for manual
    President:
  • 2,110 Answers
The problem is that you cannot run a descaling procedure while the E2 message is displayed. It tells you to reset it by unplugging the machine for 30 seconds. Except that mine refuses to reset - it's stuck at E2!
Posted on Dec 23, 2008
  • Sibananda Jena
    Sibananda Jena Dec 23, 2008
    Press the On/Off Button to reset the
    Coffee Maker. If the error codes
    reappear, there is a problem with the
    Coffee Maker electronics. Please refer
    to the Warranty and Service section
    beginning on the following page
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Error code (E2-E3)in toshiba washing machine AW1190S
Try replacing lid close sensor...mine one has E2 due to broken wire...
Feb 03, 2013 | Washing Machines
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
E2 error code in samsung split AC
From all Samsung recomendations... if your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced.
If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced.
To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864) any day between 9:00 a.m. and 9:00 p.m. Have the model number and serial number of your air conditioner on hand when you call.
Hope helps.
Jun 29, 2011 | Samsung AS18A6RB Air Conditioner
I have an E2 error message on my air conditioner. It has stopped working and resetting it doesn't help.
means you have less that 24 volts to thermostat check transformer or wireing to tstat
Aug 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
Error code E2
Hi most of the treadmill with e2 error code are related to the motor speed sensor so check the sensor
May 12, 2009 | Exercise & Fitness
E2/F2 Error
The Model number is a RBD306PDB6 i found that one as far as the code
F2=
E2 Keypad not connected
1. Check keypad connector for firm connection.
E3 Key held down too 2. Press CANCEL. If error code returns after 60 sec., replace keypad.
long, or key is shorted
Feb 17, 2008 | Ovens
KitchenAid Pro Line Coffeemaker Coffee Maker Logo
201 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
